Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
My raypack pool heater rp 2100 starts to heat and than stops, if you let it set for a few min and do it again the burners kick on than go out after a min or so?
  • 8,404 Answers
Check your water pressure switch. There could be a clog or it could be defective. I think Id remove it, turn on your filter pump and blow out some water then replace it. You can check the switch with an ohm meter. Remove the leads from the switch. With the pump on, the switch sould read "short". With the pump off, the switch should read "open".
For your heater to work, you must have fuel (gas or what ever) and you must have water pressure (your circulator pump operating).
Posted on Sep 07, 2009
  • 2 more comments
  • jigs1 Aug 18, 2011
    How to remove the pressure switch !? Just turn it counter clockwise. And when you say the switch, you mean the "whole black switch with round circular turn wheel below it and mounted to a cylindrical shape" which then goes into the inlet pipes.
    Thanks
  • A Miller Aug 18, 2011
    Pressure switch looks just like a oil pressure switch on a car ... standard pipe thread goes into the heater somewhere ... two wires attached to it on the top or side ... . To prove or disprove, short the wires out - you heater should run. If you are CERTAIN you have water flow of sufficient pressure and it runs when you short the wires together, replace the switch.
  • jigs1 Aug 19, 2011
    Thank you Milleraba, so how do you remove the switch ? With hand, just twist it counter-clockwise or use a wrench or something !? And I presume with the pump not running, right. I am not a handy person and hence being extra cautious about not messing something else.
    Yes, when I short the two wires OR hold the pressure switch down (press it down - makes a click noise), the heater starts working.
  • A Miller Aug 19, 2011
    Yes ... with the pump off ... It should come out with channel lock pliers ... lefty - loosey - rightie tightie ... Get a new switch at your pool place. You will need a little teflon tape - wind it on the threads to help seat the threads. You dont have to kill it when you put it in. Just snug it up so it doesn't leak.
    My pleasure to give you some assistance.
Raypack 2100......cfh then spark after a few moments.....what appears to be :Lo.....what could this be
check gas pressure sounds like too small meter especially if furnace or dryer is running call gas company give them added value of all gas operated appliances
May 24, 2014 | Raypak RP2100 DIGITAL POOL HEATER R265
Raypack 2100 pool heater runs for a couple of minutes then loud banging noise. heater shuts off and error code HL appears
That HL is your high limit shutting the heater down. The banging is the sound of water boiling in the heat exchanger because it is moving too slow. This is almost always the result of the bypass or governor (thermostat) not working properly, so too much water is bypassing the heater. It's not too hard of a fix.
Dec 17, 2013 | Raypak RP2100 DIGITAL POOL HEATER R265
I have a pool heater RP 2100 you set the temperature it calls for the spark -then there's usually a poof and the flame icon comes on, and the heater heats up. Now set temperature, Calls for heat -the spark...
make three attempts to get heater running. most electronic ignition heaters will lock out after 3-4 times. after it locks out error codes should present themselves.....such as ignition failure, prs, etc.
ensure proper gas and water pressure. check voltage supplied to your raypack's igniter aswell. if heater fires up then instantly shuts off, then it may be the flame sensor
Oct 04, 2013 | Pool & Spa
How to repair a Raypack pool heater that displays a ROL fault code?
simply replacing the roll out fuse wont solve your problem. those safeties open from an over temp situation or negative pressure down draft. clean out any dirt and debri from venting, inspect the underside of heat exchanger for build up or soot. ensure you have proper combustion/ventilation air openings if heater is in a shed. if heater is outdoors, Raypack is notorious for getting downdrafts back down the draft hood causing burner flames to come outside the burner box
May 20, 2012 | Raypak Rp2100 Pr406aen 406k Natural Gas...
CLK code will not heAT
Not sure about your specific heater, but if the heat won't go on, it could be the water pressure sensor or one of the temperature sensors.
May 05, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pool heater
This is an old, but good heater. Power is either stopping thru the safety loop, high limits or pressure switch, or the pilot generator is tiring out and not sending enough power to keep the gas valve open.
May 06, 2010 | Pool & Spa
Raypack RP 2100 The heater doesn't turn on, is there a reset
the electronic heater has an on off switch on the side on older models on the front on newer.the power goes to a transformer this in turn is converted to low power .
Jul 05, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
400 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
