Question about Cyberhome CH-DVD 300 DVD Player
Falty Component Jacks, displays only pink.
I hook up all three jacks to their respective jacks on both my HDTV and on my CH-DVD 300 player and the screen is pink... I don't know where I can get service. :-(
    Sergeant:
    Champion:
  • 362 Answers
Is this a new player for you, some dvd will not wotk on HDTV and some you have to set up so they will if you have had this a while check to make sure its still set up to play to a HDTV, if new check to make sure that it is set up for HDTV, and lastly you migtht make it work through an RF MODULATOR. if this dont apply please provide me with more specifics. are you sure the dvd works have you connected it to another TV. thank you james klgr. lets solve your problem
Posted on Dec 10, 2007
When I use the Y/Pb/Pr the picture is all pink when I use the S-viedo jack it's fine . I have check the Y/Pb/Pr cables and the are good???
clean the contacts terminal with contacts cleaner, can be dirty, oxide, or corrosion. and try again.
Otherwise internal the wires can be faulty, or loose or desolder. Open the DVD and check it.
God bless you
Oct 15, 2012 | Cyberhome CH-DVD 300 DVD Player
THE DVD PLAYS, BUT THERE'S NO SOUND.
Check the sound settings on your tv. go into the menu and scroll to sound. this is especially important if you are using an hdmi cable. but even with rca jacks my hdtv needed to be set up in the menu. also make sure your cables are properly plugged in ie audio -in-, audio-out
Dec 20, 2010 | Cyberhome CH-DVD 300 DVD Player
The tv is hooked up to our dvd player. We get a
hi,
Plz see to it that if all of jacks of dvd player are correctly and firmly inserted into the respectively coloured mating jacks of ur TV. If u still dont get a sound, it will be better if u purchase a new set of jacks.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Tried hooking up the DVD player and get no sound & the color is really bad. I have the red, blue & green hook up am I missing something?
You have component cables from your description. Make sure that each one is in the right slot on both the DVD output and the TV input. As for the audio, the component cables do not carry audio, so you need to hook up audio out from the DVD player to audio in on the TV. Usually red and white RCA jacks for audio plugged into their respective color coordinated ports. Good luck and I hope this helps.
Oct 27, 2009 | Haier DVD101 DVD Player
Hook up portable dvd player to tv
If you have component out jacks in the back (yellow, white, red plugs) you should be able to buy plugging them into your TV's Component IN jacks.
May 21, 2009 | Cyberhome CH-LDV 700B Portable DVD Player
Hook up not right
You may have connected the video cable to the (red) component jack. The three component jacks are always next to each other and are color coded red green and blue. The composite video jack is color coded yellow and only one cable is used for video. If you are using the component video, three separate cables are required.
Mar 22, 2009 | Cyberhome CH-DVD 300 DVD Player
What wires are needed?
You will, at least, need what is called "component cables", usually remembered as "the wire with those three colors; red, white, and yellow". Connect those little plugs to their respective jacks on the back of your player and TV; color to same color, "out" on the player, and "in" on the TV.
Nov 12, 2008 | Samsung DVD-V2000 DVD Player/VCR
Sony CD/DVD Player DVP-NS501P
There are several ways to connect the TV to the DVD player but you can only take advantage of the progressive scan option on your player if you use component cable. Component cable has three input jacks on it and they are colored Green, Blue, and Red. Your TV/amplifer must have component input jacks on the back of it to use this cable. If it does, then the input jacks on the back of the TV are usually labled Y, Pa, and Pr. The Y input is for the Green input jack, the Pa input is for the Blue input jack and the Pr is for the Red input jack. Once you have these plugged in you will next need to hookup the audio/vidoe cable that came with your DVD player that has a Yellow, White, and Red input jacks on it. The Yellow input jack is for Video and the White and Red are for audio. Both your TV and DVD player will have inputs for these so just match them up. If you do not have component inputs on your TV then just hook up the audio/video cable and it will work.
Nov 07, 2008 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Dvd screen is pink
If you are using component cables to connect the DVD to the tv make sure you have the red,blue and green colors on your cables matching these colored jacks on the tv and DVD jacks. If one of these cables is plugged in wrong or not plugged in it could cause this. Good Luck
Jan 04, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Cyberhome CH-DVD 300 DVD Player Logo
80 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
