We just got an old Kenmore gas range secondhand. The problem is that we are using LP and it is set up for natural gas at the moment (orifices too big, I think). How do we convert?
I converted a gas range several years ago, and all that was required was that I had to 'seat' all of the orfices - or tighten them down so that they are completely seated (do not overtighten!). It has been working great for years!
Kenmore Gas ranges can be used with Natural gas or Lp. They come from the factory set up for Natural gas so if you want to use Lp it needs to be converted by you or your gas company. There are several adjustments that have to be made and some ranges require orifices to be changed. Your installation manual tells how to convert it but if you're not sure about doing it you would be better off the call the gas man.
I understand that you want to convert your Natural Gas unit to LP (Propane) gas you will need to purchase a conversion kit. Please give me about an hour or so and I will locate it and the instructions to convert.
I just bought a new/used GE mongram natural gas range and need an LP conversion kit. Called GE and found them very UNhelpful. Can this be this hard? The party I called will not take the range back. $3000! I thought I got a great deal and cannot use the range the way it is. I need help too.
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting back to natural gas from LP) This range leaves the factory set for use with natural gas. If you want to convert to LP gas, the conversion must be performed by a qualified LP gas installer. The conversion instructions and LP orifices can be found attached to the range next to the pressure regulator. Keep these instructions and the orifices in case you want to convert back to natural gas.
the burner orfices will have to be changed ans pressure reg / some have either /or reg / just turn lever to the fuel you are using . but always change the orfices to gas or lp . blk is lp copper nat gas .. you can probably do it with out the instructions it's very simple .. if the other set of orfice's are not in or on range then order them for your model . ..mm
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
You have to get the right orifice's for Natural gas. LP gas orifice has twice the size hole as compared to Natural Gas. Using it without the right orifice will put out way too much gas, and you will burn everything, as well as it will be a fire hazard.
Your local gas company or propane company should be able to get you the right orifice
