Question about FrancisFrancis! X5 Espresso Machine
When we turn on the machine it cut the power in the house
When we turn on our x1 it trips all the power in the house
    President:
  • 1,618 Answers
It is possible that the element in the machine is damaged, that is the only thing that will cause that kind of damage.
Posted on Sep 17, 2009
Keeps tripping power at 13minutes remaining, just before the spin cycle
Hello. It sounds like the motor has gone bad--possibly a shorted part of the motor, or a jammed drain pump. It also could be the transmission binding at the point of going into spin mode. You didn't provide a brand/model number so my help is limited. The clue here is the clicking before the power trip.
Aug 19, 2015 | Washing Machines
My treadmill turns on but completely cuts out and trips the house fuse box.. whats wrong
Either your Motor or Motor Control Board(MCB) is faulty.
Try testing your Motor with a Drill Battery:
1. Disconnect the machine's power lead from the power socket, so that there is no power to the machine.
2. Open the Motor Hood.
3. Disconnect the Motor + and - leads from the Motor Control Board.
4. Connect + and - leads(normally Red and Black) to the Drill Battery.
The Motor should turn the Belt.
With the Motor leads disconnected from the MCB, you can connect the machine to the power, Press Start, and if this trips your Fuse Box you know its definitely the MCB.
Only carry out these tests if you are competent.
Lethal Voltages are present.
samsfitnesssolutions.co.uk
Jul 04, 2014 | Proform Crosswalk 500 Treadmill
Cut out keeps tripping
Hello there,
House fuse has blown or circuit breaker has tripped. you need to Check and/or replace fuse and reset circuit breaker. If the Power cut you need to Check house lights.
Hope this helps. All the best Elect_Comp
Sep 23, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
SEBO X1 tripped out, fuse OK, is there an internal trip to reset?
It seems I'm the only Sebo expert contributing to this site at the moment, and I'll be glad to help you but I need more information. What do you mean by "tripped out"? Do you mean it just stopped working, or what? Do any of the lights come on, or does the machine seem to be completely dead? How old is it (roughly)? What is the condition of the flex (especially where it goes in to the plug, and where it goes in to the rubber grommet on the handle)? Is the rubber grommet damaged at all? Any other damage anywhere?
The answer to your question is "no", there is no internal trip to reset. The machine will only cut out if it gets too hot (because there's a blockage somewhere) and it will reset itself when it cools sufficiently.
Feb 22, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Francis Francis..why do you turn off the power???
Generally in the case that a FF machine is tripping the GFI it is because the heating element within the boiler is coming in direct contact with the water. By this I mean that the coating on the element has deteriorated or the element itself split apart. This is usually do to a lack of cleaning or descaling. It is the machines defense to trip the breaker to avoid any further issues. As far as I know there is no way to repair this problem except sending it in to a repair center.
Hope this helps
Jun 26, 2008 | FrancisFrancis! X1 - Stainless Steel...
My washing machine is tripping the circuit breaker
sorry to hear about the problem it will be your motor or module try online for recon both these parts are prone to go on bekos
Jun 14, 2008 | Washing Machines
Francis Francis X1 Electrical Problem
Appliances that cycle power, fridges, freezers, espresso machines...tend to trip GFCI outlets. Not a problem with the machine.
Feb 04, 2008 | FrancisFrancis! X1 - Stainless Steel...
Machine not heating. Power problems
check inside for burnt spade connectors or wires burnt off the connectors. spade connectors can be gotten from radio shack or electrical supply houses or home depot.
Sep 10, 2007 | FrancisFrancis! X1 Espresso Machine
Machine fuses house RCD if a drying cycle is selected
Suggest you turn the power off, remove the top cover, diconnect the live and neutral connections to the dryer element (likely to be two of each flavour of connection if the machine has high and low dry settings). Pop a bit of insulating tape around the wire ends so you don't short anything out. Now try to put the machine through a drying cycle. If it works (albeit cold) without tripping the house power, you need a new dryer element. If the house power still trips, turn the power off again and without reconnecting the element wires, disconnect and tape the live and neutral wires from the blower motor. Again, try to run a drying cycle. If this stops the house power tripping, then it looks like a motor problem (though this would be quite unusual). If the house power still trips, you need to have a careful look at all the wiring between the main timer, the dryer timer, any hi/lo heat switch, the blower motor and the element with its associated thermostats and thermal cutouts (all located near the element on the air duct). Look in particular for chafes where wires go round corners, and where wiring crosses from the case to the suspended machinery in the middle of the machine. Pop any follow-on queries in the comments section of this question - I'll keep half an eye on it. A.
May 19, 2007 | Hotpoint Aquarius WD63 Front Load...
FrancisFrancis! X5 Espresso Machine Logo
189 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
