Question about Car Audio & Video
I have a 2005 ford taurus with a cd changer located in the trunk. I had to jump start my car and now the radio doesn't work and i can not get the cd changer to open.
  • 3,230 Answers
First of all you check for fuse, it seems blown. Check your fusebox in the cabin, if fuse are ok then must be that the jump damaged the cd player, also try to reset your radio by pressing the reset button.
Good Luck!!
Thanks
Posted on Sep 07, 2009
2007 ford taurus air bag light on after replacing stereo
The CD changer option is similar to the single-disc player. The CD changer has the ability to toggle between the stereo and the multi-disc changer. In the 2007 Ford Taurus, the CD changer is located either in the vehicle's trunk or in the center console and has a magazine that can hold up to six CDs.---------------------------------------------------------------------------------------
Launch CResetter Oil Lamp Reset Tool
Mar 07, 2013 | Cars & Trucks
I have the same exact problem as the person who posted the following, which is so well written that I couldn't improve upon it: The 6 CD changer in the trunk of my 1999 Ford Taurus SE stopped working all...
this sounds like the belt in the changer has broken, this belt operates the tray that hold the magazine, so its trying to eject it but is not moving upward also this belt spins the discs, you will need to remove the unit and had a belt out in it, ive had a couple of these repaired it cost about 100.00 dollars, at an audio repair shop also had one that the carriage was bad. hope this helps.
Oct 04, 2010 | 1999 Ford Taurus
My radio doesn't have a cd but there is a button marked cd. Is it possible there is wiring in the trunk for the cd changer i have?
Usually they don't do that. We have a 1998 Ford Taurus that has the button for the cd but no wiring for a cd changer in the trunk. You can check for yourself if you like.
Aug 03, 2010 | 2003 Mercury Grand Marquis
Loction of cd changer plug
the unit at front with the ac controls is just a remote control unit , the radio is in your trunk left side
you have to remove the carpet and you will find a free 13 pin plug , that is the cd changer connector
it is the same in all taurus and sable from 1996 to 2007
the radio looks like this picture
this is the cd changer
Apr 01, 2010 | 1997 Mercury Sable
1999 Ford SE digital display reads ''NO CD'' and changer is stuck
Magazine-type CD changers are prone to jamming with a disc in transit between the magazine and the player. You may have to resort to disassembling the trunk unit to get access to the jam.
Apr 15, 2017 | 1999 Ford Taurus
Where is th cd changer in a taurus gl 97
The CD changer is in the trunk, left had rear trim panel. It is along the body so the trim or carpet material will have to be pulled away.
Nov 03, 2009 | 1997 Ford Taurus
Can not find where to plug CD player to the harness
does the radio have cd changer controlls? if so you may find the wires in the trunk if not you will have to buy a harness from ford and make sure the cd changer will work with the stock radio. Call the local ford dealer parts dep but make sure you have the vin number from the car with that they can look up the car and tell you what options where installed from the factory and can order the correct cable
Sep 02, 2009 | 2000 Ford Taurus
...where is the **** cd changer/player in my taurus 1998 lx?
that cd button is for an external changer that you must install yourself. once you install the the changer then all you have to do is press that button and through the circuit you can get your cd music.in order to install the changer you have to purchase a link cable to the the vehicle from the changer. you will not have to cut or splic any wires at all get the connector cable and the changer and once installed your all set. the plug in for the changer is in the trunk of the vehicle. now you will not have access to insert the cds while driving because that is not how the system works in a conventional sense like a cd stereo does
Apr 26, 2009 | 1998 Ford Taurus
Renault espace radio will not turn on jump started the car
Test all of the fuses and replace as needed, review your owners manual for all fuse box locations...
Good luck
Feb 22, 2009 | Pioneer CDX-FM687 6-Disc CD Changer
I have a '99 Ford Taurus with a cassette and 6 changer cd player. The radio works for a while then cuts out, then comes back on. It can play for a few hours or a few days. I recently bought another radio...
yes i agree it sounds like it is overheating. Just pull back the carpet in the trunk on the left hand side. Check all the connections make sure its got a good ground etc.
This unit is where all the power etc comes from for the headunit and speakers.
Oct 28, 2008 | 2004 Ford Taurus
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
