Question about Garden
Lack of power
I have an old IDC 500-1 supreme weed trimmer and I am looking for the recomended air gap for the coil magnet. Thanks.
Ron
  • 155 Answers
Hi usually about 10 thou for most units.
Posted on Sep 10, 2009
Testimonial: "Thanks for your input. I have not checked this yet but I will within the next week. I know someone had this unit apart so I will let you know. Thanks"
What is the air gap between the coil and flywheel on Ryobi 700r weed trimmer
Set it at about .010"-.012". That is about the thickness of a standard business card (which many use to do just this same repair).
Sep 11, 2011 | Ryobi Garden
How can I trouble shoot the kill switch on a echo weed eater. The spark plug is good as it has ben tested on another machine. There is no spark and seems the kill switch should be the next obvious thing...
Check the kill switch terminals with a continuity tester (small multi-meter will work). If the switch is Ok and there is no spark, take off the engine cover and check the "air-gap" between the magnets in the flywheel and the ignition module legs.The closer the better, but you want about a ,008-.010"gap there...about the width of a standard sized business card. Metal feeler gauges "stick" of course to the magnet area in the flywheel and throw off clearance sensitivity. Try it with a business card. If not in range, then loosen the coil screws, double the card over, and let the magnets pull the coil legs into the card...retighten screws and check for spark.
Mar 15, 2011 | Echo Garden
Igntion coil on echo trimmer went bad, replaced with echo blower coil . there is a small difference in design but now have ignition. Engine still won't start.
Make sure the air-gap between your used blower coil module and the magnets on the Echo's flywheel is about the thickness of a regular business card. That is about .010"-.016". The gap HAS to be present in order for the module to produce the spark.
Oct 01, 2010 | Echo Rapid Loader, Trimmer Head
AHOW TO SET AIR GAP ON TB 70 SS
The Torx head screws holding the coil in place have to be loosened. They may be tough as sometimes when assembled, the factory uses Threadlocker on them (alongwith the cylinder bolts). If you have removed covers and are at the flywheel/coil area rotate the flywheel till the magnets in it line up with the leg or legs on the coil. Insert a business card (folded in two) in between and let the magnets "draw" the coil onto the card. The proper gap is about .010-.014" or so. The closer the better. Make sure to tighten the coil screws extra tight. You can coat them with some thread lock if you choose so they can't vibrate loose. The business card gap works on most small engines.
Aug 14, 2010 | Troy Bilt Tb70ss Gas Trimmer
25 cc craftsman weed trimmer.\r\nNot getting spark
If you're sure it's not getting spark, the first thing to check would be the "air-gap" setting between the magnets on the flywheel and the ignition coil module . The correct setting basically only requires the use of a regular business card and is around .010"-.014" If there is an air gap present, check it and then you can move on to diagnose the coil module ( they don't go bad very often) if necessary.
Jun 08, 2010 | Craftsman Garden
String-trimmer (weed eater) won't start.
the only thing left is the coil that is inside the cover right next to the flywheel with a gap of 10 thousand of a inch a business card will work but a new coil is almost thr price of a new trimmer unless you have a used one
Nov 05, 2009 | Garden
No spark
The easy way is just use a buisnes card it work great,I hope this helps you And thanks
Sep 11, 2009 | Garden
How to replace coil on stihl fs85 weed trimmer
Remove the starter & cylinder cover and look for the coil mounted next to the flywheel. Remove the 2 screws holding it to the cylinder and cafefully pull the wires through the clips that hold them to the block. Install the new coil in the reverse order and set the air gap between the flywheel and the coil with a business card. Let the magnets on the flywheel pull the coil towards it with the business card in between. Tighten the screws and spin the flywheel to remove the card. Reassemble the stater and blower housing.
Sep 05, 2009 | Garden
What should gap be between ignition module and flywheel magnets on troybilt 575ss 4 cycle weed trimmer? It is a year 2006 model.
Pull the module back, tighten it up and align magnets on flywheel with module. Put a business car between them and loosen the module. It will move against card. Tighten the screws there. It's set.
Jun 27, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
What are the timing specs on a Husqvarna 36-r string trimmer
there is no timing spec . the air gap is .010 to .012. or .254 mm to .305 mm.open the gap all the way up and tighten the screws.bring the flywheel magent to the coil making sure that both sides of the coil is on the magnet.slide the gapping tool in and the magent will hold it in place.once it's there release the screws holding the coil and the magents wiil pull the coil to it.once it's there retighten the screws and your done.
Mar 12, 2009 | Husqvarna Garden
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
