We hit a button on the remote and lost the Tuner, so we can't get any channels. I think we hit the factory settings mode. What can we do to get the tuner back?
  • 157 Answers
The tv is problably in video input mode-find eithor input or video on remote push it until tuner function appears -if you need more help get the model number of tv and repost it
Posted on Sep 07, 2009
Without remote how do I set in on channel 3, the channel button of front of TV only goes from 95 to 99 and back again.
you will need the remote to do a channel search or manually reprogram the tuner to tune in ch3
A good place to fine cheep factory remotes is on e bay. enter your model and make, only buy factory remotes not universal .
Factory remotes can do things a universal one cannot.
Jan 23, 2016 | Televison & Video
LEDTV24FHDF
You should be able to get OTA (over the air broadcast) just make sure you have an antenna plugged in and that the tuner is set to AIR.
Setting the Tuner Mode
If you are using a device that is connected to the RF input, such
as an external antenna or cable TV connection, you must set the
tuner mode.
1. Press the MENU button on the remote. The on-screen menu is
displayed.
2. Use the Arrow buttons on the remote to highlight the
Settings icon and press OK. The Settings menu is displayed.
3. Highlight Tuner and press OK. The Tuner Mode menu is
displayed.
4. Highlight Antenna or Cable and press OK.
5. Press the EXIT button on the remote.
Scanning for Channels
Before the TV can detect and display channels and their
associated information, you must scan for channels. A channel
scan may also be necessary when the TV has been moved to an
area where different free-to-air broadcast television channels are
available.
1. From the Tuner Settings menu,
highlight Auto Channel Scan.
The auto channel scan begins.
2. Wait until the channel scan is
100% complete. Highlight Done
and press OK.
3. Press the EXIT button on the
remote.
Apr 08, 2014 | Televison & Video
I own an old Sanyo VCR VWM 680. I have not used it for quite sometime & lost the remote control. I need to use it as my cable channel selector. Since its in the VCR mode, i cannot switch it to TV...
actually the tuner is in the vcr mode.
to get the channels to set,you have to autoprogram the tuner,and then they can be changed using the up down buttons.
rca make a universal remote for 10 bucks that will run that vcr
Feb 13, 2010 | Sanyo Televison & Video
Universal remote works for basics but won't change input
Rich,
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
cheers,
mark
Jan 31, 2009 | Toshiba 32A33 32" TV
Need to re-set my tv
if u whent into the setup mode. u may have put the tv in a video mode what u need to do is turn the set on hit the menu on the remote control and tell me what it says on the screen if it shows video 1 tru 4 inputs u need to chage the inputs in the setup untill u see a channel number channel 4 or 10 that way u know that u are in tuner mode and video mode i hope this helps marty
Aug 25, 2008 | Panasonic PT-51HX41 51" Rear Projection...
No channels on the list
Be sure that you are on the "Tuner" input, and that if you are using a converter box, that you have the set tuned to the single channel that the box puts out. (In the US, that's either 3 or 4.)...accordianman
Jun 30, 2008 | Olevia LT32HVE 32 in. LCD Television
Won't receive channels above 18, cable not at fault
Your "tuner" in the menu is set on "off air" or "antenna. It should be set on "cable" or "dish". See if you can go into your menu with the buttons on the set and change your tuner setting. Keever
Mar 06, 2008 | Sharp 27L-S100 27" TV
TV Tuning on ALBA TV with DVD player
you start with tv,dvd mode to your remote control when you have alread make sure your in tuner you hit menu mode and show you the instruction select arrow shows _ + try it.
Nov 16, 2007 | Televison & Video
Can't get any channels on the air.\
If the tuner is the problem then it is a very bad problem as the tuner is part of the DM module and that is very expensive. When you say you have to manually key in the channels, do they work then? If so the problem is not the tuner. If your only problem is that you cannot go from one channel to the other by using the channel up and down button on the remote, then you have most likely just lost the programming on the tv. Go into menu and set up and find the auto channel programming and run auto program to correct the problem.
Apr 28, 2007 | RCA HD50LPW42 50" Rear Projection HDTV
No display with DVD, VCR, or tuner
It sounds to me without knowing the model or type unit that you may need to unplug tv AND take batteries out of remote for a few seconds, replug and start over. Hope it helps
Dec 09, 2006 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
