Question about Akai Dc7370 Digital Camera
Power won't come on even with new batteries. - Akai Dc7370 Digital Camera
    President:
  • 2,761 Answers
It may be something more serious, or your new batteries may be defective, but the problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion buildups may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment, clean the contacts at both ends of the batteries, and reinstall them in the camera. Assuming that the batteries are fresh/fully charged, this takes care of about 90% of the startup problems. I hope it works for you.
Posted on Sep 07, 2009
Batery won't charge new battery n plug
You may have the wrong AC adaptor, Dell is very picky when it comes to Power adaptors, it must be original OEM Dell for the laptop to recognize it, any after market no name brand even though it has the right specs and is made for your model will power your laptop but the circuit to charge your battery will automatically be closed
Nov 17, 2012 | Dell Studio 1737 Laptop
My hp pavillion laptop will not charge my battery . It won't even work without the battery but plugged in with power supply even though i know battery and power supply are sound.
It won't ever be a 'software' issue....it will be either a :
Adapter/Charger issue (Have it tested by local PC repair shop.)
if it is good, then it is the other prob. If it is not good, then buy a new one.
OR
Laptop power connector issue. (expensive repair.)
Sep 06, 2012 | Toshiba Satelitte M300 St3401 Core 2 Duo...
Nikon S8100 digital camera won't power on even with new battery.
1_ recharge the batteries or replace
2) clean the contacts batteries with contacts cleaner very well with carefully
3) see if the battery is loaded in WRON direction
4) memor card slot/battery cover is open.
5)poor contact between camera and battery terminal adjust the contacts and clean.
God bless you
Jul 31, 2012 | Nikon S8100 Digital Camera
Nikon coolpix S8100 won't power on even with new battery.
10 replace batteries or recharged very well the batteries.
2) clean very well the contacts batteries from oxide, dust, dirty. or corrosion
3) batteries loaded in WRON direction
4) batteries is NOT the right type
5) poor contact between battery and cover , clean and adjust it .
6) Memory card slot/battery covert is open
God bless you
Jul 31, 2012 | Nikon Coolpix S8100 Gold Digital Camera...
My mechanic has just put a new starter motor on my car, it's been sat there for a while, and even with the new starter, the engine won't turn over, please help. Cheers
What is the battery amperage? It is possible that the starter is defective as well even though it is new. If you dont have enough power in the battery it will not turn over. Could be a starter solenoid as well depending on the make model...
Jun 07, 2012 | Cars & Trucks
I changed my battery in my G5 and now it wont start. There is power to the car. Lights and power locks using the wireless button even works. What can be causeing this?
You can't fix it yourself. It takes a scanner at your Local Dealership to do it. People do it, (new battery) everyday unaware that doing so can and usually does, arm the theft system and either kills the radio or the whole car. To me it's just another built-in defect that requires dealer assistance. It's a buzzkill I know, and it probably won't be long until car owners won't even have access to the engine compartment.
Aug 26, 2011 | Pontiac G5 Cars & Trucks
My darango won't start, replaced that alternator and relays. starter is still good. but it won't even click over.
this could be as simple as a bad battery have you tryed to jump start it? if you try and that dosent work make sure you have power going to the starter with jumper cables on the battery. it should at the very least make a clicking sound while trying to start it check the battery posts also make sure they are clean and if it does click give it a minute and try starting it again.[ dont take the cables off the battery while waiting] the fact the starter doesent even click when you try to start it tells me no power to it or bad starter remember just because its new dosent mean it works i cant tell you how many times i have put somethig on a car and had to take it back off because it didnt work from the boxx new. and make sure the starter wires are tight and clean. if no clicking and you have power to starter then starter is bad.. i hope this helps..
Jun 04, 2011 | 2006 Dodge Durango
ALIENWARE DESKTOP LOST ALL POWER
In a laptop, you can lose power in three ways.
1. Dead battery 2. Dead Power cord. 3. Bad motherboard.
ther first two should be rather obvious, as the battery won't work or it won't hold a charge, but if it won't turn on at all, even while plugged in, chances are that you're going to need a new motheboard. This can be expensive in the M--x laptops, unfortunately.
Sorry for the bad news, mate.
Apr 29, 2011 | Dell Alienware M11x Gaming Laptop Computer...
Why won't camera switch on and red light flashing all the time i have bought a new battery but still won;t switch on and light still flashing many thanks
hi, what type of batterys have you brought as most normal batterys you buy wont even switch the camera on you need hi power batterys such as lithium or even better go into a camera shop and they will have special high power bats, normal bats wont even switch mine on so give different batts a try
let me know how you get on or if you need fyrther assistance ok
Nov 10, 2009 | Kodak EasyShare Z730 Digital Camera
Akai Dc7370 Digital Camera Logo
Top Akai Cameras Experts
Tony Parsons
Tony Parsons
Are you an Akai Camera Expert? Answer questions, earn points and help others
