Cannon MULTIPASS C530  Printer
Problem for Cannon MULTIPASS C530 (REFURB) Printer
After cleaning the head on our MP500 there are still streaks
By pacificwave on Sep 07, 2009
On the test page there are streaks in the first magenta line and the second line is barely visible.
Best Solution
posted on Sep 07, 2009
Very Helpful)
kitajib
Rank: Guru
Rating: 87%, 208 votes
This is more than likely a ink cartridge failure. If you are using after market/or refilled ink cartridges, I would try an OEM cartridge to clear the problem. The non-OEM ink has probably clogged the nozzle.
Change the cartridges, run a deep cleaning on all colors, run alignment and the test page. The problem should clear up.
Sometimes non-OEM inks are not up to specifications and cause this problem.
Let me know if this clears the problem.
Please make sure to rate this solution. Thanks.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Cannon MULTIPASS C530 Printer
Questions and Unsolved Problems for Cannon MULTIPASS C530 Printer
Do you recommend Cannon MULTIPASS C530 (REFURB) Printer?
Answer
Answer
My Cannon MP360 says the Waste Ink Tank is nearly full and will not print.
Answer
how can i connect my home phone to printer to recieve faxes as well as phone calls
Answer
tengo un multipass C530 quiero saber si hay algun programa para hacerlo funcionar con windows Xp o... (More)
Answer
I've changed both cartridges,Cleaned the print head,w/ alcohol and Q-tip,Still half prints some... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Cannon MULTIPASS C530 Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
