Question about Homelite Mighty Lite Lawn Trimmer
Will only run on choke and doesnt stay running
Took carb off cleaned it, made sure all gaskets are sealed , no gas line leaks . this trimmer has been a pain since ive gotten it, ty china for another quilty product....why do we Americans keep buying their junk !
5 Suggested Answers
  • 45 Answers
SOURCE: Homelite string trimmer mighty lite
does it have spark? did you replace the plug?
Posted on Apr 29, 2009
  • 4 Answers
SOURCE: Homelite gas trimmer will not run without half choke and throttle
did you try fresh gas
Posted on May 31, 2009
#1 Taper
  • 1040 Answers
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Posted on Jun 02, 2009
  • 5 Answers
SOURCE: trimmer wont stay running
the top line from the gas tank goes to the front nipple on the carb, the lower line from the gas tank goes to the back nipple on the carb
Posted on Sep 07, 2009
My gas trimmer starts but wont stay running
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, !!
Feb 20, 2012 | Troy Bilt Tb70ss Gas Trimmer
Gas Trimmer will not stay started
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
Jul 02, 2008 | Ryobi 15" Electric Factory Reconditioned...
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
My ryobi grass trimmer will only run on 1/2 choke model RY 30524
Check for fuel supply problems (clogged cap vent, dirty tank fuel filter, clogged or faulty fuel intake lines, leaky or cracked primer bulb, air leak in rear crankcase cover...check 4 screws above gas tank, air leak in carb gasket...check carb nuts, trashed up carburetor...needs cleaning or rebuild, mixture screws need adjusting)....a myriad of possibilities here but I would guess it's a dirty carb....hope it helps
Jun 27, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Yard machine ym26ss straight shaft trimmer. New gas,
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 12, 2009 | Yard Machines Garden
Craftsman Weed Eater only runs on choke (not at all now!)
Check the mounting screws holding the carburettor and the plate behiend the carb, they often become loose, also the gaskets, they might need renewing. Your carb. could need cleaning and new diaphrams. stephen.
Sep 20, 2009 | Craftsman 25cc Gas Line Trimmer
Trimmer wont stay running
Sep 06, 2009 | Homelite Mighty Lite Lawn Trimmer
Engine dies when excelerating - more gas
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Nov 17, 2008 | Homelite Mighty Lite Lawn Trimmer
Weed trimmer
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Sep 02, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi weed trimmer
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal. i
Jul 06, 2008 | Ryobi 15" Electric Factory Reconditioned...
Homelite Mighty Lite Lawn Trimmer  Logo
165 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
