Question about Kitchen Ranges
I have a Whirlpool Gold oven model GW395LEGB5 that won't heat. The broiler works fine. Sometimes, after the broiler is lit, the oven will heat up. But no more. Just the broiler works. Is this something I can fix myself?
  • 5,911 Answers
If the broiler works fine, but the oven does not, more than likely this is caused by an igniter that has gone bad. The intermittent symptoms you were experiencing is a sign that the ingiter probably became weak due to age and finally failed. The following link explains how these igniters work and how to replace one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Since both oven manifolds are fed from the same gas source, this can be narrowed down to an igniter problem. Your oven should have the Norton type igniter. The part number for a replacement is 9782065 and can be found at appliancepartspros.com for about $71, You can search around if you like, but this was the cheapest I could find it.
Your oven has interchangeable igniters. Meaning the broil manifold and bake manifold use the same type of igniter. You can swap igniters while awaiting parts, if you wish to use the oven to bake.
NOTE: If the connector plug on the ingiter you receive does not match the receptacle in your stove, you will instructed to cut the leads and connect them together using ceramic wire lugs (included in the kit you receive). Do not attempt to use standard wire lugs as they will melt. The wires and ceramic lugs are heat resistant.
If you have any questions, or need additional assistance, please let me know. I hope this helps you.
Posted on Sep 07, 2009
Testimonial: "That was exactly the information I needed, thanks."
My 9 year old unit has the same exact symtoms - broiler works baking doesn't. I smell gas, can see a glowing igniter but no flame. Apparently it isn't hot enogh to ignite it.
Your information here was very helpful
Posted on Jan 17, 2010
Whirlpool Gold Series stove. When turning on the oven to pre-heat, the broiler came on and we got a fault saying FAULT - PRESS ENTER TO RETRY.
Appears the burner is faulty, check connection at burner receptical first then check with meter for opens. Here is the Whirlpool link for parts repair manual etc. https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.whirlpool.com/services/replacement-parts.html&ved=0ahUKEwiCvdH97rDTAhVk7IMKHX4gAtMQFghZMAA&usg=AFQjCNEsdfUwvP3qyVcDj7qJikAtiHTfUQ
Apr 18, 2017 | Whirlpool Kitchen Ranges
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Whirlpool electric oven not heating (has a functional stove top)
Hello Daniellel583! We are terribly sorry to hear of your concern with your Whirlpool Range. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Daniellel583), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 18, 2017 | Whirlpool RF111PXS Electric Range
Top broiler element works sometimes but not often
Sounds like an iffy clock control. You could try replacing it, but it ain't cheap.
May 21, 2010 | Whirlpool RF364 Electric Kitchen Range
Oven broiler and auto clean not working.
if the oven broiler isnt working self clean wont either check the broiler element to see if its burned out pretty easy to replace most of the times you can replace it from inside the oven be sure to turn the power off then remove the two retainers from inside and pull element out
Jan 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kitchen Ranges Logo
188 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
