Whirlpool washer, model LA5460XT, will not spin unless I open the lid and then close the lid. What does it need?
    President:
  • 1,776 Answers
It sounds like you have a malfunctioning lid switch. Check out the video at the link I am providing and see if it helps you in the right direction. Sure hope it does and best wishes.
http://www.youtube.com/watch?v=fC8SY3cU1Yc&feature=PlayList&p=A8EAB62928245279&playnext=1&playnext_from=PL&index=61
Posted on Sep 07, 2009
Washer will not spin r drain model whirlpool la7680xmwo
Sounds most likely a broken/defective lid switch. The lid switch on a top-load washer is a safety switch that detects whether the top-load washer lid is closed. The lid must be closed when the basket spins; some top-load models require that the washer lid be closed before the washer drive motor runs (thus no draining). If the lid switch isn't properly detecting whether the lid is closed replace the switch.
Dec 24, 2016 | Whirlpool Washing Machines
My washing machine fills up with water but does not continue the wash cycle. Sometimes when you slam the lid the washer will continue the wash cycle to the end. Other times the washer stays filled up...
Sounds like the lid safety switch is either out of adjustment, or needs replacement.
Most washers will fill with the lid open, but no continue a cycle where the drum or agitator spin, unless it senses the lid is closed.
Oct 01, 2013 | Whirlpool Washing Machines
When i close the led hard it works why?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Assuming that the machine will neither wash nor drain/spin unless you "slam" the lid, the problem points to a loose / damaged Lid Switch.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Oct 12, 2010 | Kenmore 15864/15862 Top Load Washer
My Kenmore 80 series will wash, but when it gets to the rinse it won't spin or drain water? I had used it the day before and it was working fine with lid open or close. Didn't have to close the lid for any...
It sounds as if the Lid Switch had been stuck in the closed position and something caused it to open and stick open.
Oct 12, 2010 | Kenmore 24032\24036 Top Load Washer
Washer wont run unless i forcefully push the lid when closed
It is a simple and relatively inexpensive fix.
Jul 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Problem with spin in rinse cycle
Yeah that is a lid switch problem. I have a page I compiled that shows how to fix this easily: HERE
Jan 28, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Sounds to me like you have a bad lid switch. They will loose their connection sometimes and the only way you can get it to work is lift the lid and close it again. You can go to www.partselect.com and enter your complete model number. It will take you to diagrams of your machine. From there you can find your lid switch and can also order it. Good luck.
Nov 25, 2009 | Whirlpool GSW9800PW Washer
Spin Cycle Not Working
the most common problem when this occurs is the lid switch has broken inspect it if not click when lid is closed replace the switch you see if you can get local it saves some shipping cost unless they are outragious then order on line
Aug 07, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool Ultimate Care II washer will not spin...
I would say you have a burnt out clutch. did you over load it with a quilt or comforter?
Time to consider a new washing machine, unless its under warranty I would recommend replacing the washer vs. fixing it.
Whirlpool doesnt build them like they use to!
Jul 11, 2008 | Kenmore 22422 Top Load Washer
Will not drain
Some machines will agitate with the top open but need the lid closed to drain/spin. Your machine should have a hidden lid switch attached to the lid hinge. This "arm" is probably out of position and will need to be bent slightly to engage the switch. You should hear a faint mechanical click as you open and close the lid. The cabinet will have to be removed from the machine to correct this.
Jan 23, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Top Washing Machines Experts
