Question about Epson TM-T88III Thermal Printer
THE LOGO PRINTS BUT I CANNOT SET THE CORRECT SIZE
THANKS FOR THE PREVIOUS INFO
I need to Print The Logo Double Hight / Width
The Command is FSp1 3,51
The command prints the LOGO but ignores the 3,51
Please can you say me how to set correct margin size for Printer Zebra Xiiii plus
choose the "View > View Options" Menu with the BT document open and now enable the "Show Unprintable Region" checkbox. Will you now see the unprintable width margins covering part of the left margin of your label? If yes, then this means that due to the unprintable width of the printer you cannot print on this are (this the related to the printers print head tolerance).
With regards to the not being able to print on the bottom side, this could be a page setup issue. Please attach your BT document to this forum topic by using the "More Reply Options" button.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Techsupport Printer
Feb 26, 2014 | Zebra Xi Series 140Xi4 - label printer -...
I CANT PRINT THE CORRECT SIZE
Hi!
fixed the 203 dpi new head in zebra 105sl printer then 1 week print is correct size to 4x6 inches label but after 15 days its not comming full page print.
pls help to get soultion
thanks / Khokan
Jul 15, 2012 | Office Equipment & Supplies
How do I print an envelope
Change settings from an application for current jobs (Windows)
  1. Open the document that you want to print.
  2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
  3. Next, click on the tab labeled "Paper/Features."
  4. Click the "Type Is" pull-down menu and select "Envelopes." Select the "Size Is" drop-down menu and click on the size of the envelopes you have loaded in the input tray. If you do not find the correct size, click "Custom" and type the height and width in the window that opens, then click "Save."
  5. Click the "Source Is" drop-down menu and select "Tray 1." Click the "OK" button at the bottom of the window to save your settings, then click the "Print" button to begin the print job.
  6. After you have finished with the settings, click OK, Print, or a similar command.
Here is your manual, for future references: http://h10032.www1.hp.com/ctg/Manual/c01669504.pdf
Mar 10, 2011 | HP Officejet 6500 Wireless All-in-One...
Canon LASER SHOT LBP-1210 Printer how to set legal page
For printing the Legal Size (8.5′x14′) in cannon LBP-1210, follow the instruction:
Step 1- Go to start
Step 2-printer and faxs
Step 3-select printer(Canon LASER SHOT LBP-1210)
Step 4-go to file
Step 5-select Server properties
Step 6-select creat new form (for legal page)
Step 7-give form name legal 1
Step 8-give paper size width 8.50in, hight 14.00
Step 9-give paper margin top 0.30in, left 0.30in, right 0.30in, bottom 0.30in
Step 10-select save form Step 11-then select advanced
Step 12-select informational notifications for local printers
Step 13-select apply
Step 14-then close
Step 15-select Canon Laser Shot LBP-1210
Step 16-select printer
Step 17-select properties
Step 18-select-select forms
Step 19-select change forms
Step 20-select legal 1
Step 21-select OK
Step 22-select apply
Step 23-select OK
Remember: 1 U need to set paper size (8.5′ x 14′) manually in the word documents and befor printing you need to set in printer properties "Legal 1′ for printing. Print preview may not show the whole page but the printer will print the whole page.
All the best.
Apr 24, 2010 | Canon LASER SHOT LBP-3000 Printer
Eltron 2844 prints previous job over and over
Make sure the label size is correct, if the print encounters a gap before it is complete; it will re-print the same label. In MS Word make sure the page size is set to the correct size including any headers and footers and Width etc.
Sep 17, 2009 | Zebra TLP 2844-Z Thermal Label Printer
I have an HP 5550 Series Deskjet printer. Only recently, I have encountered difficulty printing labels. I have double-checked the Printing Properties, including label size, label paper size, Avery paper #,...
This printer have the capabilites of sense the size of label, each colomn width.
So, you must set the right size of colomn width, in your application (ms. word) to match label width.
May this help.
Oct 10, 2008 | Office Equipment & Supplies
Legal size paper on LBP-1210
Step 1- Go to start
Step 4-go to file
Step 14-then close
Step 21-select OK
Step 23-select OK
Remember: 1 U need to set paper size (8.5′ x 14′) manually in the word documents and befor printing you need to set in printer properties “Legal 1′ for printing. Print preview may not show the whole page but the printer will print the whole page.
All the best.
PARVEZ [ info(at)parvezbd(dot)com ]
Jun 22, 2008 | Video Cameras
How to change paper size on axerox phaser 8500
From a Windows Operating System:
  1. From the computer, open the document to be printed within an application program.
  2. Click on [File] on the toolbar, and then click [Print]. The Print window will be displayed.
  3. Click on the [Properties] button, or the [Printing Preferences] button. The Properties or Printing Preferences window will be displayed.
  4. Click on the [Paper / Quality] tab.
    NOTE: Most applications will automatically provide the page size information to the driver. If not, steps 8 - 10 describe how to create a custom page size.
  5. Select the required paper size from the Document Size pull down menu, if available.
  6. If the required custom paper size is not available click on the [My Customer Sizes…] button.
  7. To create a new custom paper size setting click on the [New] button.
  8. In the Name field enter the name to be given to the custom paper size. For example 127 mm x 394 mm (5 in. x 10 in.)
  9. In the Width field enter the width of the custom paper size.
    NOTE: The width should always be the short edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the width must be set to 127 mm (5 inches) regardless of the orientation of the document or the feed method on the printer.
  10. In the Height field enter the height of the custom paper size.
    NOTE: The height should always be the long edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the height must be set to 394 mm (10 inches) regardless of the orientation of the document or the feed method on the printer.
  11. Click on [Save]
  12. Click on [Close].
  13. Select the required paper size from the Document Size pull down menu.
  14. Click on [OK] twice to print
From a Mac OSx:
  1. Click on [File] on the application toolbar, and then click on [Page Setup]. The Page Setup window will be displayed.
  2. From the Printer Description pull-down menu, select the correct PPD file for your printer.
  3. Select the custom paper size for your document from the Paper Size pull-down menu.
  4. If the required custom paper size is not available click on the [Manage Custom Sizes…]. The Custom Page Sizes window will be displayed
  5. To create a new custom paper size setting click on the [+] button.
  6. Double click on [Untitled] and enter the name to be given to the custom paper size.
  7. At the Page Size field enter the width and height of the custom paper size.
  8. Click on [OK] twice.
Apr 22, 2008 | Office Equipment & Supplies
Does not print pictures
hi suvi please tell us more about your computer and printer setting.. However, i have some question.. 1) Does your printer print another logo or any other picture correctly like before? & 2) Which software did you used to print your logo? Thanks, waiting for your response
Aug 29, 2007 | Epson Stylus C46 InkJet Printer
Configuration settings do not save in 'Permanent' mode
Q#1, is the DPI the same as the other printers? there is also an option in the menu to rescale DPI that could cause the issueprint out a setup label from the printer and compare it to one of the other printers.
May 24, 2007 | Zebra Z4M Printer
Epson TM-T88III Thermal Printer Logo
283 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
