Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
The drip pan
I can't find it on my amana bottom freezer refigerator
Take off the toe grill on the bottom of the refrigerator and the drip pan will be sitting down low in the left hand side of the opening. You have to lift it up and pull pretty hard to get it out. If you have pet hair ( and probably even if not) you should periodically vacuum out the coils in this section -- you can see them when you remove the drip pan. I just got a LOT of dog hair out of mine last night.
Posted on Sep 16, 2009
  • caflaf107 Sep 16, 2009
How do i replace the cracked drip pan in the french door refigerator
  • Unplug the refrigerator from the power source and remove the decorative vent cover at the bottom of the fridge under the door. Some vent covers are screwed on but many just snap onto clip that hold them in place.
  • Pull gently on the exposed front edge of the drip pan and ease it out towards you. The drip pan slides on runners on each side of the bottom of the refrigerator. It may be full of liquid or debris so go slow and steady and then discard it.
  • Line up the new drip pan with the two side guides beneath the refrigerator and slide into place. Use the flashlight if to make sure the drip pan is in the groove on each side.
  • Clean and replace the vent cover by clipping or screwing it into place. Plug the refrigerator back into the power outlet
  • Dec 15, 2013 | Freezers
    Amana bottommount refigerator--ABB1922FEW--- BUY 08-03-07 AMANA REFIGERATOR WARM---60+ DEGREES FREEZER ---YES---10 DEGREES FREDD- APHASIA--COMMUNICATION PROBLEMS--- NICKNAME: giesslerf PASSWORD: abd7f
    Wow
    Ican not understand what you need.
    So I am guessing here
    Ice has built up on the evaporator coil stopping air flow to the food section.
    Try manually defrosting the fridge. If this works then the auto defrost cycle has failed and you will need to get a technician to help you
    Mar 30, 2011 | Amana ABB1922FEW (186 cu ft) Bottom...
    Hi I have a Whirlpool Refigerator and it drips water from the frezzer into the refigerator thru the two opening up in the back middle opening from the frezzer to the refigerator. It does this off and on
    sounds like the drain live from freezer to outside is clogged. the water isnt making it you the condensate pan but coming out in the refrigerator. try finding and cleaning the drain line.
    Mar 02, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
    Amana upright freezer leaks water on floor instead of in drip pan under it.
    check the flor of the freezer if it is caked with ice your defrost drain is clogged
    if not
    take off the back panal
    under the machine follow the drain tube
    to the drain pan clean out your duck bill and make sure the tube is in the pan
    Oct 06, 2009 | Amana 16.7 cu. ft. / 473 liter Upright...
    Pooling Water
    Hi!!!Your drain line is frozen and plugged.Try to remove the cover of the evaporator and you should see a small hole on the base of the evaporator thats yout drain line hole. Blow it away and your problem is gone..Good luckk..Plugged drain line..
    Dec 23, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
    I cannot get to the drip pan under refridgerator to empty it. It is filled with sludge and smells bad
    Thank willie for helping with one: "Well, it looks like the pan is a seperate plastic pan and not the compressor mounting pan like some of the newer ones are. It appears that you have to remove the condensor fan motor and mounting bracket then maybe the pan will left up and over the compressor, or maybe there is enough room to lift the pan up and out the front over the condensor coils"
    Jun 04, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
    Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
    124 people viewed this question
    Top Amana Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
