Question about Sony KDS55A2000 55" HDTV
The tv goes off by itself and comes on by itself
I had to pull the plug on this unit until I can afford to call the repair man out. I tried to count the blinks the green light is flashing , but there all different combinations. I have had this unit for almost 3 years and had had the light changed in it once and shortly after that had somthing called a color block changed. Now this.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This might have happened due to over-voltage. Please check the power supply unit for swollen/bulged capacitors and burnt wires/components on the power supply board of your TV. Also check this link for the meaning of blinking codes. You should try and turn off the TV for 8-10 hours to reset it. Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Mar 30, 2010
My sony bravia model KDL-46EX500 is three years old. It has worked fine until this morning when I tried to turn it on. The cable box and everything else comes on. I unplugged it for an hour, but it still...
Have you checked the power cord is firmly connected to the power source (wall plug? or wherever) and have you checked the cord connection into the tv?
Pull them off and reconnect
If the red (standby) light does not come on, then you have an internal problem and these cant be fixed without opening up the tv. Dont do it- it has to go to the dealer
Mar 05, 2014 | Sony Televison & Video
Sony kdl-46w5100 shuts itself off then goes to stanby flashing 10 times
I have the same tv with the same problem, replace the power supply boards and still had same problem, called in a tv repair man and I was told I have a main board problem bu board Watch Dog Timer used to track micro processors, led flashing 10 times cost around $425 parts and service call
Feb 24, 2012 | Sony KDL Televison & Video
Philips tv with sound going in and out
Try bypassing the set's speaker by running an external audio amp. I use my bookcase stereo for audio direct from the satellite receiver and turn the volume off on the TV. Sounds better this way! Could be the audio amp in the TV is going bad or the speaker may be bad and the TV's audio amp goes through a shut down cycle.
Feb 10, 2010 | Philips 30PW850H 30" TV
Sony kdp-57ws550. Turn on tv = no picture, have
You have to count how many times it blinks. It is a service code. The main thing that goes on these is the convergence chips. If you had the back off doing any type of repair, recheck your plugs. Odds are, you crossed one.
Dec 12, 2009 | Sony Televison & Video
My toshiba 44g9uxe lcd projection tv has a dull picture my neighbour told me it might need a lamp replacement but the indicator light does not come on to notify me that it needs replacing please help i...
If the picture is looking darker than normal then yes I suspect the lamp. The lamp indicator on the front of the TV is just a timer that is preset warning you that the lamp is about to expire. The timer actually has nothing to do with the actual usage of the lamp itself.
Dec 01, 2009 | Televison & Video
Need Help with tv problem
tiene que revisar la tarjeta de comvergencia
Aug 26, 2009 | JVC AV-48P575 48" Rear Projection...
Tv switched itself onto standby and now will not turn back on. tried unplugging it and plugging it back in but it still won't come off standby. when you press the button on the remote it goes green for a...
unit seems to go into protect mode.Theres very little that can be done..There is good chance unit needs to be checked at a repair shop.Try to find one that is authorized for your particular brand if possible
Aug 05, 2009 | Televison & Video
Samsung plasma hd ps42097
Sounds like your power transformer is going bad inside the unit. Time for a repair man to visit you. Be warned, it's not going to be cheap. If you have a battery backup on your computer, try plugging the TV into that and see if it continues to shut down. If so, it's definately time for a repair man.
Steven
Sep 06, 2008 | Samsung PPM42S3 42 in. Plasma Television
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Volume keeps going up by itself
help the volume on my tv keeps going up and no one is touching it! please help. my parents cannot afford a new tv
Mar 29, 2006 | Apex Digital PF2025 20" TV
Sony KDS55A2000 55" HDTV Logo
82 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
