Question about Karcher Garden
Engine starts fine , little water out the nozzle , but the engine just pulses , doesnt seem to build enough pressure . karchar 2400 psi w/honda engine
    Sergeant:
  • 384 Answers
The nozzle is dirty!!!! It's always the nozzle. Clean out with a small diameter thru the nozzle.
Posted on Sep 09, 2009
Why does my pressure hose burst when I use a turbo nozzle
Turbo heads are pressure rated for different pressure washers, your turbo head is most likely rated bellow the maximum pressure of your washer which in turn causes a pressure build up in the hose and it's eventual failure.
Sep 24, 2014 | Honda Pressure Washer PSI 3000
I bought a new 2600 psi pressure washer. It starts great. The pressure starts out fine. However, when I disengage the spray nozzle lever and then push it again there is along delay before I get any...
Hi. I think the problem may be called either vapor lock or cavitation, or it could be called something else, but the solution is to take the wand apart in the center and let the trapped water escape, then putting it back together before re-engaging the lever.
Sep 14, 2011 | Craftsman 2600 PSI Honda Powered Pressure...
Honda pressure washer 2400 psi worked fine yesterday, today the pressure is low, seems to work fine except the level of press sure is low any suggestions?
Check for an inline filter on the water hose connection, the low pressure side. Depending on your water quality and if any spiders made homes inside your hose, they can get clogged pretty easily.
Jun 07, 2011 | Garden
I do like to know if this washer is good enough for my business as a used car dealer? Briggs & Stratton Murray 020456 2400 PSI 20 GPM 190cc Briggs Stratton
We power washed houses for years with a 2400psi machine. The machine weighed about 90 pounds. 1 strong man could pick up the weight, but usually it took 2 men to unload it from the trailer.
A small machine can advertise 2400 psi ... but that is for 3 square inches at a time. The heavier machine shoots a 10" or wider swath of 2400psi.
We ran our machine twice a week for years. We had a honda engine. I'm sure the briggs engine is good. I wouldn't buy a used machine... unless the price was low and it started on first pull. Electric starter on your power washer might be a repair-waiting-to-happen because it is constantly exposed to water and dirt.
Oct 19, 2010 | Briggs & Stratton Murray 020456 2400 PSI...
Pressure washer worked fine and suddenly no
If you remove the tip, will it work? If so, unloader valve is sticking and needs to be removed and lubed with lithium grease.
Jun 29, 2010 | Honda 2500 PSI Gas Pressure Washer
Husky 2400 psi honda engine ran fine all day
It sounds like the bypass valve is stuck. Do you have a parts diagram?
Jun 27, 2009 | Honda Garden
I have a karcher 2400 psi pressure washer and it doesnt get water pressurized when pulling wand trigger.
the most comon problem with thease is a stuck bypass valve, this is the valve that alowes the water to bypass round the pump when the triger is closed, when they stick all of your pressure runs around the pump and not out of your nozzle,,
its located in the centre of the pump on the top, undo the 2 cap screws pull out valve greese and re fit
Jun 08, 2009 | Honda Karcher G2400HH-R Pressure Washer
Garden Logo
283 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
