Question about Daewoo KOC-925T Microwave Oven
Plscti/ teflon coating inside the microwave
The plastic coating inside my microwave has started pealing off. can the coating be done again.
  • Daewoo Master
  • 9,128 Answers
Is it plastic or paint? I would be surprised if it were plastic, as that would probably not withstand the microwave energy.
If it needs to be repainted, that can be done if it is cleaned and dried.
High temperature appliance paint is available from stores like Wal-Mart or Lowe's.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 04, 2008
My Microwave got bubbles on the top ( ceiling). Is it still safe to use it or better to get a new one..( this one must be around or over 10 years old..) Need an answer asap please..
Hello, Elke -
By "bubbles on the top (ceiling)" of your microwave, do you mean it seems that the paint / interior coating is bubbling and may eventually peal off? If so . . .
Read the information here:
https://www.hunker.com/13407894/the-inside-of-my-microwave-is-peeling
The well-respected U.S. magazine, Conusmer Reports, which evaluates the quality of a variety of consumer items, states microwave ovens have an average life expectancy of 9 years. See:
https://www.consumerreports.org/cro/news/2009/03/by-the-numbers-how-long-will-your-appliances-last-it-depends/index.htm
Best wishes.
Apr 12, 2018 | Microwave Ovens
Is my microwave safe to use if the inside of the oven is pealing?
Most likely if the metal screen in the door is intact. That screen and the metal cover on the back and sides surrounds the insides of the oven reflect the microwaves back into the oven. Just be careful about the peeling plastic inside.
Jan 26, 2015 | Microwave Ovens
The metal is showing inside. The white coating is pealing. Is this dangerous?
The peeling of the white coating inside of the microwave oven is dangerous in terms of creating a fire hazard and potentially contaminating the food you cook within it. This can be prevented by cleaning up all splatters and spills immediately before using the microwave oven again. You can fix the peeling by replacing the microwave oven or repairing it. To repair it, you will have to remove the peeling coating and then repaint the interior of the microwave with paint that is designed for microwaves in general. Though, if you do this, you will have to let the paint dry up for at least 24 hours. I hope this helps you!
Feb 10, 2012 | GE Microwave Ovens
Is it possible to restore the teflon surface of teflon coated pans on which the surface has become scratched (in this case Jamie Oliver Tefal Frying pans)
No. There is no effective repair procedure for the pan once the teflon coating has become scratched down to the bare metal or begins peeling off.
You can continue to use the pan safely, but the non-stick surface will not be as effective as an undamaged coating would be.
Never use metal forks / spatulas / utensils on a teflon coated pan.
Instead try using thermal rated plastic, teflon, or wooden spatulas which will not scratch the pan coatings.
Good luck.
Jun 12, 2011 | Microwave Ovens
I have Ultrex II cookware. the nonstick interior is peeling off several of my pans and getting into the food. very disappointed. hope it is not a health problem.
most of this is teflon plastic , you have probably eaten worst . but there is a spray replacement to re-coat your cook work. just heat high and spray on and cool off and done non-stick again foe a few years at least . some can be purchased @ Walmart. or on Ebay hope this works out for you. use only plastic or wooden spoons etc, not metal it scraps it off again ....... >
Dec 20, 2010 | Microwave Ovens
Inside my Daewoo KOR-6Q27 microwave oven, underneath rotating glass plate, white layer (or paint) have piled off and rust have started to emerge. Can this problem be fixed or i have to buy a new one? Was...
I have painted many Microwave oven cavities. You have to sand down the pealed off rusted areas and completely clean and degrease. Before painting, I use laquer thinner as a cleaner degreaser. Fumes can be a bit strong but it has worked well of me. I normally buy an automotive spray paint. They have a lot of different colors and a lot of the import colors can really come close to the color inside the microwave. Spray on thin layers till you get good coverage and make sure you let it dry thoroughly before trying to use. The paint in a Microwave isi not a special microwave energy protective paint. it is only there to make it look pretty and protect the metal. So a good automotive paint normally works fine.
Sep 25, 2017 | Daewoo Microwave Ovens
I am having problems with the coating on the inside of my pans. It is coming off. What can I do?
If you are referring to the teflon coating, the only thing you can do is throw them away because that teflon is very cancer causing and toxic. How old are the pans? Just go to walmart and buy another set.
Thanks,
Lee
Oct 19, 2010 | Microwave Ovens
The motor is starting to squeak.From using it last week and again today it is getting louder and the housing is very warm. Thank you!
if the motor you hear squeaking is the internal fan (not the vent fan if it has one) then that will have to be replaced or lubed. if that fan stops working then the magnetron will be damaged very quickly ... servicing inside the microwave is a bit dangerous ... make sure it is always unplugged anytime the cover is off ... the voltage and current inside is potentially fatal .while its plugged in ... if the internal fan is slowing down then the magnetron will get very hot. .. if you are handy you can re-lube the magnetron cooling fan by removing the cabinet (unplugged of course) ... use a lite machine oil or oil designed for very small motors .. don't use teflon oil or WD40 .. good sewing machine oil is ok ... make sure the plastic mounting for the fan is ok and not warped or cracked ... make sure the fan blade doesn't touch anything and turns freely .. if you are not mechanically inclined then you might get an estimate for repairs .. often a new microwave costs less than repairs to an old one ..
Jul 29, 2010 | Hamilton Beach Microwave Ovens
I'm getting a flash inside the oven and the plastic on the inside roof has a burn mark. I removed the plastic cover over the micro wave generator and it did not spark. is the oven dying? It is a 1983 0ver...
It looks like the metal part inside the oven is exposed to the high frequency rf waves. this may sound strange but try coating the metal part with fresh paint. remember no metal inside the oven will stand the waves created inside the oven the spark u see is the waves hitting the exposed metal part inside the oven
Oct 13, 2009 | Magic Chef MCD1311ST Microwave Oven
Daewoo KOC-925T Microwave Oven Logo
661 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
