Question about Garden
Mower deck how do i level the deck on mu mtd 38'' cut mower?
  • 8,404 Answers
MAKE DARN SURE THE POWER IS OFF BEFORE YOU START THE PROCEEDURE BELOW! there should be 4 connection points for this machine. Clear out your garage ... get something comfortable to lay on and a small supply of proper supply wrenches and a tape measure. put the deck in UP position. put the blades perpendicular to the front to back axis of the machine. Measure from the floor to the blade tips on the outside. record the numbers. turn the blades 90 degrees. repeat. adjust the proper corner slowly (no big changes!) continue to measure until the numbers are equal.
Low on the left - change the adjustments on the left front and back. Low in the front - lift the front - both sides.
It took me several hours to do my mower when I got it new but I was pretty particular about it
Posted on Sep 07, 2009
Mower deck diagram.
Check with SearsPartsDirect,com they will help you
May 05, 2016 | Mtd Garden
I need a diagram for deck belt on a 1989 lawn boy lt 12 38 " deck
it's usually on top of the deck clean off the grass and look on top may have to remove it to see
Oct 19, 2012 | Mtd LAWN MOWER PART # 983-04052 DECK...
My MTD 14hp lawn tractor (38", 6 speed) shuts of
You have a short somewhere . A cut or stripped wire that , at the time of lowering your deck, touches the body. It's like turning off your key. Look around under your deck and you will find what I'm talking about. Fix wire and tie up to prevent future problems. GOOD LUCK.
Jun 16, 2011 | Yard Machines MTD Gold 20 HP Lawn Tractor...
I have a yard man 13AH762F752 How do I know what size my deck is I thought it was a 38" and bought v-type belt and it is to shore so how do I find out my deck size?
If you have a single idler pulley you should have a 38" deck. If the deck has two idlers, then you must have a 42"deck. You should be able to approximate by measuring. This is the "cutting" width, not overall width. Two things might have happened. You didn't get the right belt, or you haven't routed it properly. Here is a link to the Yardman web site to download your manual if you don't have it. It appears that the 38" deck requires a longer belt than the 42" deck. http://manuals.mtdproducts.com/mtd/Public.do?langId=-1&BrandCode=10201
Jun 18, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Mtd riding mower: right mower blade cutting uneven, but don't see problem
The blade can be bent or the deck is not level. Adjust the deck and level it from side to side. Now level it from front to rear with the front of the deck 1/4" lower than the back. If after leveling it, you find it still cuts uneven remove all blades and inspect them. You will more than likely find one is bent. Replace a bent blade.
Sep 18, 2009 | Garden
How to adjust mower deck height
There should be two threaded rods with a nut on them that goes from the frame to the deck. Check the height of each blade and which ever side is out of balance you can disconnect that sides rod (usually held onto the mount with a clip or cotter pin) and turn the rod to either raise or lower your deck until it is level.
The above was for leveling your deck.
If you just need to raise or lower the deck depends on if you have a lever on the right side with a push button on top just depress the push button and push forward to lower or pull back to raise.
It might have a round knob that you turn to raise or lower.
Good luck
Sep 03, 2009 | Garden
I can't get my deck back on my lawn tractor.
if you still have the manual for the mower you can find out how to replace the deck. If not try going to the MTD online manual and find the lay out for the proper deck replacement.
Jul 12, 2009 | Mtd Garden
I have a mtd 13.5 horse 38 inch cut 6 speed its around a 2007 or a 2008 i need to se how all the belts go on the mower deck and drive
Most mower decks have the diagram on them, if not go to MTD.com and put your model number to see the diagram.
May 02, 2009 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Garden Logo
79 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
