Question about Linksys Wireless-G WRT54G Router
I HAVE A LINKSYS WIRELESS-g 2.4 BROADBAND ROUTER, 54MBPS. HOW DO I HOOK IT UP TO A MOTOROLA S85101 CABLE MODEM? I KNOW NEXT TO NOTHING ABOUT COMPUTERS
  • Linksys Master
  • 8,404 Answers
Your router had a outlet marked Internet. You need a CAT 5 cable to plug into that outlet. Plug the other end into the same kind of hole on your modem. make sure your cable is connected. Turn on or plug in your modem. Count to 30. Plut in your router. Count to 30. Turn on your computer. Wait for it to boot up. Use the wiundows wizzard to setup your connection.
Posted on Sep 07, 2009
Need to know how the cables hook up
ISP line (DSL or Cable from wall) --> Modem (given from isp ,eg :motorola,arris ,speedstream ect) -
-->router isolated port (Says modem , should be in isolated color) -->computer ( from any one
ethernet port of router )
Oct 07, 2010 | Linksys Wireless-G Broadband Router
I want to set up my Wireless-G 2.4 GHZ 54Mbps
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 17, 2010 | Linksys Wireless-G Broadband Router
How do I remove linksys broadband WRT54GS Wireless-G router from my pc. and revert to just my Motorola, SB5101 surfboard cable modem. Tried simply removing the router and pluging the modem back in, but no...
Hi intriguedkiw;
Yes this is fairly simple. Open up your network connections and delete the icon for the local area connection to the Linksys router, and click on Add new connection to create a new connection to the Cable modem. The add wizard will walk you through connecting to the modem, just fill out the questions correctly, and you should be good to go.
Good Luck,
Mark
Please dont' forget to leave a rating.
Feb 19, 2009 | Linksys Wireless-G Broadband Router
Linksys wireless-g broadband is not hook up to comp. the cord from cable modem the by pass is on to the comp.
If you want to use the linksys, you need to connect the cable from the modem to the linksys, then use another cable to connect the computer to the linksys. If it does not work, call linksys technical support, if they cannot help try this http://technicalsupport.blog.friendster.com
Feb 18, 2009 | Linksys Wireless-G Broadband Router
Connection
Hi Susie
With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
Here is a video as well on it?
http://in.youtube.com/watch?v=vSAXMO7aNzg
http://tinyurl.com/5tqqhl
Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
Thank you
Rakesh
Dell Laptop Expert
Jan 09, 2009 | Linksys Wireless-G Broadband Router
Moto modem to Linksys wireless router
You have to reset the modem from behind (little pin hole) with the modem and router not connected via ethernet, the let it restart and reset the router after both are reset connect the ethernet cable between them.
Nov 21, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Need tech advice
No and why doesn't your internet provider... provide a cable modem?? Did you just ask them to enable broadband internet service? So now you'll have to provide your own cable modem.
If what you say is correct you need a cable modem like a motorola surfboard from BestBuy.... then the cable modem plugs into your Linksys router and your PC's plug into the linksys router also.
http://www.bestbuy.com/site/olspage.jsp?skuId=8229044&st=motorola+surfboard&lp=1&type=product&cp=1&id=1168043113583
May 05, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
