Question about GE Spacemaker JVM1640SJ Microwave Oven
GE SpaceMaker JVM XL1800
Our microwave oven has only been in use for about 1 1/2 years and recently broke down. One day my wife was cleaning in the kitchen area when she heard a loud popping sound generating from inside the microwave. The unit was not in use at the time of this incident. I quickly ran to the kitchen and unplug the unit. Trying to investigate, I've removed the vent cover beneath, right away I've found pieces of glass from the light bulb scattered on the vent dropdown cover. Apparently, one of the light bulbs exploded inside the socket.
After removing the remainder of the bulb from the light socket with plyers, the socket appears to be fine. With a multimeter, I measured the socket voltage to be ~14V. So, I went ahead and recycle power to the unit. The control board powered up but went haywire, nothing seemed to be working except for setting up the clock. I've pressed the fan button and vent fan came on but will not shutoff. The unit does not respond when commanded to heat after entering cooking time.
This is the weirdest thing I've experienced with a supposively superior microwave from GE. Any clues as to what might have happened? I can't imagine that a surge would do this to internal circuitry of a microwave. You would think the unit has a primary fuse that will protect all senstive electronics, to say the least blowing up a light bulb. Hum.... I am at a loss, please help!
KC
  • Kevin Chau Dec 10, 2007
    Thanks for the feedback and help. We did schedule a service GE service technician. He came in and said the control board had to be replace before further work. He wasn't able to do anything on power up similar to what I've stated. He was nice enough to give it to us under warranty and order a I believe what you called 'ERC' board. I just took a quick peek and it's an open face component mounted on one side and printed circuit board on the other. Does that sound like 'ERC' board? Anyway, luckily GE has been pretty decent on their customer service.
    Hum.. any thing I should do to protect this from happening in the future again? I was thinking about getting a surge protector just for the microwave oven. Will that help or not? I don't want my microwave to start any fires when I am not home like some of the other articles read online about some of GE's recalls.
    Your thoughts! Again, thanks so much for all your help. Happy Holidays to all!
    KC
  • 35 Answers
Sounds like the ERC board failed. It maybe covered under warranty, check that first cause a new ERC could cost around $150-$200. Anything electric can cause the .."what the*^&% just happened syndrome.
Posted on Dec 09, 2007
Rubbing alcohol was spilled down back of GE microwave in the move over 1 year ago. Is the microwave still usable or will the alcohol cause a fire?
Alcohol evaporates. Put a few drops of alcohol in a paper cup and leave it overnight. It should be gone in less than a day. A year should evaporate a lot of alcohol.
If you want to be extra safe and you're tech-savvy, open the case carefully and look for moisture. Otherwise, plug it in somewhere relatively safe and try it (fire extinguisher Class C or ABC handy. -- You need an BC in the kitchen anyway. http://garages.about.com/od/toolsmaterials/a/fire_extinguisher.htm).
Once tested, put the microwave where you need it.
Aug 16, 2013 | General Electric Microwave Oven
I have a Baumatic microwave BTM17.3SS. It came along with our new kitchen approx 4 years ago. We usually only used it for warming things. Recently it has stopped heating!! It still rotates and lights up....
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Jun 14, 2011 | Baumatic Microwave Ovens
Problem with the GE Spacemaker (JVM1640SJ) Microwave Oven GE Spacemaker XL1800 won't heat food anymore....It worked this morning, now won't heat. What should I do?
GE Will replace the magnetron for 9 years! Mine is a 2004 model with a one year warrently according to manual. HOWEVER they did say the magnatron was covered for nine years: call 888-239-6832. When I called they said thats all they get calls for and would send out in 3-5 days. NO CHARGE. I had to ask if there was coverage longer than a year on major parts and that's when they offered the info and I eventually was transferred to the right office. Saved $120 bucks on parts alone.
Jun 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Sharp R-305KS stainless microwave. It is about 1 year old and until recently, I haven't had any problems with it. About two weeks ago the cancel button on the front panel started to work...
Hi and welcome to FixYa, I am Kelly.
This microwave has a 1 year warranty. You are going to need a new keypad to correct your symptom. Let Sharp pay for it.
http://www.sharpusa.com/~/media/15710197EE3140AD888B896ACDC912DD.ashx
(Choose "open" ) Then go to page 2 for contact information. Page 3 sates Parts and Labor 1 year.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Sharp R305KS Microwave Oven
MYS SAMSUNG MICROWAVE'S TURNTABLE HAS STOPPED WORKING. IT WAS INTERMITTENT FOR A FEW DAYS. THIS HAPPENED WHEN MY WIFE TRIED TO BOIL EGGS IN MICROWAVE AND THEY SPURTED.
Possible that the temperature cut off sensor has switched off. check on the panel side after opening the top cover and see the continutiy . check the inside of oven and clean well the fitting area of the magnetron. Check if fuse is blown.
It is possible that the magnetron was working dry and burnt out.
So if all the other sections are fine and the relays ae clicking then it should work. If not clean the door latch switch.
Remove the plug from the outlet and let the microwave reset. the controller/timer can then be set back with the clock.
Hope this works.
Aug 27, 2010 | Samsung Microwave Ovens
I have a GE Spacemaker XL1800, no heat and a humming noise.
magnetron problem DON'T KNOW IF WITH FIXING - WOULD LIKE TO KNOW MYSELF
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
In model spacemaker xl1800 no heating but all
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gfj
Jan 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
508 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
