Question about Printronix Line Matrix P5010 Printer
Searching for Printronix P5010 WindowsXP printer driver.
IBM Proprinter driver 64 bit
There is no proprinter Driver for 64bit. You can use the Epson emulation or the P7000 driver with the printer in its native emulation.
Mar 12, 2014 | Printronix Line Matrix P5010 Printer
Driver for xp
Hi
This unit is no longer supported.
Feb 20, 2014 | Printronix Line Matrix P5005B Printer
Driver download
You can use the P7000 Driver from the manufactures website.
Jan 25, 2014 | Printronix Line Matrix P5010 Printer
Printronix 5 series printer driver
Have you done an online search for the drivers you are looking for? Usually if you do that you will find the web site that contains the drivers you need to download to get the printer to work.
Mar 23, 2012 | Printronix P5010 Matrix Printer
I am getting a constant Ribbon stall on one of our p5010, we have totally cleaned hammer bank areas and put in new gold ribbons, we compare ribbon drag on the stalled p5010 to our many working p5010 and...
there are few things.. may be your ribbon hub damage... your ribbon motor not working properly.. check ribbon motor connection...and finaly L/C..CMX..CFX board.
Mar 10, 2010 | Tally Compaq Line Printer LG05 500 LPM...
P5010 line printer, I want to print in condensed mode
This can be done by sending an "escape sequence" to the printer. Basically you create a text file using Notepad and then print it. Of course the magic escape codes to do this are found in your P5010 Owners / Users Manual. I don't have a copy at hand. If yours has been misplaced, you're pretty much out of luck. As a long shot you can try the standard Epson codes for condensed print.
Jan 01, 2009 | Printronix P5010 Matrix Printer
Printronix p5010 with AS/400 IBM server
I can get the P5010 printing on your AS400... But, there are to many things to check without knowing a little more about your environment.
If you can't ping the PTX P5010 from the AS400 or a PC, then you have a printer configuration problem.
Take the printer offline and hit the Print Config button. and then the enter on OPs Panel. Then post top or first paragraph of the config. so I can look at...
__________________________________________________________
If you can ping the printer from the AS400...
You will need to create a remote out que on AS400... command is crtoutq then hit F4...
if you can't post the printer config here... Fax it 972-233-7306, Attn: P5010, Toby
Dec 12, 2006 | Printronix Line Matrix P5010 Printer
Printronix Line Matrix P5010 Printer Logo
302 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Cliff
Nick
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
