Trying to hook up to ps3 using HDMI to DVI cable with Hanns G 174D monitor. CAn only see blank screen, any solutions?
  • 916 Answers
Hook up the PS3 so you can see the screen. Then go into the display settings and lower it to the lowest resolution settings. Then try connecting it again.
Posted on Sep 07, 2009
When using PS3 on RCA D52W19 TV, the screen does not fit ( it is zoomed and off-center) in 1080i resolution.
hello!
Have you tried to toggle "format" or "screen size"? On those sets non HD and HD settings could be adjusted separately. Try that, first. If no luck, try similar settings on PS3. I bet, you will be able to match screen format there, as well. To me it looks, like picture formats are mismatched. Also: try to use "component" cables, instead of DVI adapter cable, if nothing works.
good luck,
Alex.
Feb 16, 2012 | RCA D52W19 52" Rear Projection Television
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
I have my PS3 hooked to the HDMI port, but the monitor won't switch inputs to the HDMI port. If I have something plugged into the dvi port it works fine, but I currently need only the HDMI port, and do...
There are a varity of HDMI cables, ensure that your version is supported also using the input touch "button" to change the input through VGA, DVI and HDMI.
damnor01
Nov 22, 2010 | Acer H233H bmid Monitor
Hooking up ps3
To get 1080i (the 50V will not do 1080P) from the Blu ray player you do have to use HDMI output on the PS3 to the DVI input.
I found one at Walmart. Phillips makes an HDMI to DVI plug also at Wmart.
The PS3 must be set for the output you want on your TV.
Look in your manual in the PS3 box or go to http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
The web site has much more detailed instructions, but the basic answer to your question is below.
  • The cable required to output a particular video mode may not be included with the product and additional purchases may be necessary. For details, refer to the documentation supplied with your system.
  • If the video output settings do not match those required for the TV in use, the screen may go blank when the resolution is changed. The screen should, however, automatically go back to its original resolution after a while. If the screen remains blank for more than 30 seconds, turn off the system. Then touch the power button on the system front for at least five seconds to turn the system on again. The video output settings will automatically be reset to the standard resolution.
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
  • Copyright-protected Blu-ray video discs can only output at 1080p using an HDMI cable connected to a device that is compatible with the HDCP standard.
  • Hope that helps!
    Merry Christmas and Happy Holidays to you and your family.
    Dec 14, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
    My monitor says cable not connected
    If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck
    Jul 03, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
    Blank Screen using HDMI-DVI cable for PS3
    Sounds like your LCD monitor isnt HD compatible.
    Mar 17, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
    DVI port not working
    change the resolution of the screen the computer does not suport that resolution, if you chang that will be ok.
    Jan 19, 2009 | NEC-Mitsubishi MultiSync 1735NXM Monitor
    Acer H213H No sound
    Dude, the hdmi is just for the video signal, you'll have to use a separate audio cable to get sound from the integrated speakers.
    Jan 02, 2009 | Computers & Internet
    Hdmi to dvi
    This message may occur if the signal from the video adapter exceeds the scan range of the monitor (monitor not HD enabled).
    The video adapter setting on PS3 for updating the screen (the refresh rate) is incompatible with the monitor.
    Mar 28, 2008 | Computers & Internet
    Computers & Internet Logo
    423 people viewed this question
    David Payne
    David Payne
