Question about Canon PIXMA MP130 All-In-One InkJet Printer
'Put in Cartridge
My printer shows 'put in Cartridge' at all time thou i've replaced with the new one. Once, i replaced it, the head doesn't seem to move at all. On my window screen upon printing it shows 'appropriate printer head is not installed'. What could be the problem? my printer is canon pixma mp110. thank you
1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank)
2. Wait aproximately ten seconds then press the <ON/OFF> button again.
3. Wait until the device has completed its cycle befor submitting job request.
Posted on Dec 25, 2009
After printer said ink cartridge was empty I removed it & found it was not-I put it back in printer & now getting error message that the cartridge is used & needs to be replaced. How can I
your only option it to replace it with a new one . printer mfg's have chipped the cartridges and they can not be reused.unless the chip is recoded as new .
Aug 16, 2017 | Ricoh Aficio GX3050N Printer
Stripy off colour printing
You likely have separate ink cartridges and print heads on your printer. Double check your printer manufacturer and model on the net and see if that's the case. You likely will have to either replace the print heads. I've also had to clean the membrane between the cartridge and the print head which gets a dried coating on it periodically. try recommended isopropyl alcohol and water mix and put a few droplets on the membrane, let sit for a half hour and see if the droplets have passed through the membrane to the heads. Although all the efforts usually are in vain in the older type printers, if head replacements doesn't work, or what i suggested, then get a new printer. It 's cheaper. and the new ones have solved a lot of the older dried head problems.
Apr 20, 2012 | Canon PIXMA IP5200 InkJet Photo Printer
The yellow cartridge shows a "?" when needs to
According to your problem, first clear the cartridge head. Go to the Printer properties and clean the head. Check the nozzles and align the cartridges from same place. Clean the cartridge head 2-4 times. If it doesn't solve your problem then replace the cartridge.
May 04, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
Full cartridges = empty :S
Solution 1
Once you remove the ink cartridge from the printer, you can make use of the Isopropyl Alcohol, and put at maximum of 10 drops in the ink cartridge. You will find a hole there, in which the ink usually runs from the ink cartridge to the head of the printer. When done, you can put the cartridge back in the printer and run the auto cleaning process from the printer's option in order to clean the blocked holes of the cartridge. I would suggest you to run print tests first and once you are satisfied with the results, you can start using the printer normally.
If you want to go further:
* Remove the tank.
* Connect a hose directly on the inlet ink.
* Locate the sensor of reservoir and press it to make as if a cartridge is available.
* Close the cover of the print head and clean the head by injecting air (under pressure) through the pipe.
* Replace the tank up and do a test print.
* Repeat the procedure several times if the nozzles are clogged.
Solution 2
Using a syringe and some alcohol to unblock the holes can also be very effective.
* Step 1: Remove the cartridge from the computer
* Step 2: With the syringe, take in some alcohol and put in some drops in the tiny hole where the ink runs from the ink cartridge to the head of the printer.
* Step 3: When done, put the cartridge (only where the tiny holes are found) in some warm water. If some ink runs in the water, it means that the holes have been unblocked.
* Step 4: Hence, let the alcohol act for 20 minutes on the ink before putting the cartridge back in the printer.
* Step 5: Run some test prints before using the printer normally.
Note: I would suggest you to do an automatic head cleaning each time before any printing task. Hence it will reduce the risk of having the print heads blocked by dried ink.
Jan 02, 2010 | Epson Stylus 880 InkJet Color Printer
Fading prints and new cartridge error, will not aliegn
It's possible it is the new cartridge, but it sounds more like the print heads. I had the same printer and same problems until I changed the print heads. You are better off buying American Made Printer Ink Cartridges Even If They Cost A Little Less Than Name Brands. I get mine from www.officeinks.com with a 1 year quality and satisfaction guarantee with free return shipping. I have used it once and had no hassle.
Oct 16, 2009 | HP Officejet 5610 All-In-One InkJet...
I put a new cartridge in and I printed and I had a line on the paper. I took the cartridge out and cleaned it off. Then put it back in, now when I print it seems like a melted plastic smear is on my...
your printer head is damaged.. i recommended to you that you buy a new one or replace your printer head.but the printer head of the printer and a new printer has the same cost.. cheer
Sep 16, 2009 | HP Office Equipment & Supplies
Epson NX400 works but will not print any ink on the paper
did you remember to pull the tape off the print head before you installed the new cartridge?
May 28, 2009 | Epson Stylus NX400 InkJet Printer
Canon Multipass F30 not printing
Did you remove the tab that covers the cartridge head where the ink comes out, if the drivers and software that you loaded on your pc work
good and your printer shows under device MGR, then it is the printer
itself,,most times you can not see how much ink in the cart,,,most are sealed,,,just try to put the cart in again and make sure it is locked in good,,try running the cleaning program with pc,,make sure the right
cart is in the right spot, bl in one spot and color in a spot.
Dec 30, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Cartridge error
remove the cartridge & install the new one cartridge other wise
May 10, 2008 | HP Photosmart C5180 All-In-One InkJet...
I think I need a new print head/black
it seems as if, the printer is not recognising the cartridge.
if the cartridge has a chip. carefully wipe it with a cotton bud or swab. also do the same with the mating side on the printer itself.
also try uninstalling ** and unplugging the USB Or ribbon Cable** if applicable. re-install drivers and software. this is a printer problem most likely. ensure you,ve pushed it firmly into it,s holder. these need to be aligned precisely.
hope this helps Mike @ Compurepair.
Feb 20, 2008 | Brother MFC 420CN All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
429 people viewed this question
old marine
old marine
