Question about Dell Computers & Internet
Im trying to run Line 6 guitar port on a Dell 910 but it coughs and pops from time to time and the rest of the time it sounds rough i tried dpclat latency checker and it says the drivers are''bad'' I've switched off etherport and WLAN and disabled bluetooth Even playing an mp3 file from the onboard SD card turns all the green to yellow and red on the dpclat I have a big old fragile Esystem 3087 which runs Guitar Port and Guitar Rig 3 - like the 910 its 1.6GHz cpu 1.2(2)GB RAM xp home SP3 so why wont the Dell do likewise? The 910 is great as a netbook but why cant it handle audio? Ive downloaded all the latest drivers from Dell I run Gamebooster which switches all the background things off What if i remove everything but the OS and Guitarport - will that do it?? Help!!!
TJBeta
  • 67 Answers
SOURCE: Recording Issues In Vista
Microsoft moved the particular option that you need to enable since Windows XP, and have also changed its default to MUTE.
To hear what is playing through MIC IN...
  • Go to Control Panel and select "Sound"
  • Under the "Playback" tab, double click on your enabled speakers.
  • Select the "levels" tab, and look for "Mic In Volume".
  • Click once on the speaker icon that is muted to un-mute it.
I really hope that this has solved your problem, if it has not, please let me know and I will do my best to help you further. Good Luck!
Posted on May 15, 2008
SOURCE: Device Manager shows VIA SATA RAID Controller with Yellow "!"
same problem.....for help contact dragosdogaru1985 yahoo messenger
Posted on Dec 19, 2008
SOURCE: problem installing sound driver on emachine M2352
I had the same problem after doing an OS reinstall. The owner didn't have her recovery CD and the emachine website audio driver was no good. I was thinking it may of been a hardware issue but after checking all of the cables and finding nothing obvious and then finding others online who had the same problem it all pointed to the driver.
http://www.e4allupgraders.info/dir1/motherboards/laptops/arima_W730_K7_downloads.shtml
Use the audio driver from there and you should be good to go.
Posted on May 07, 2009
  • 161 Answers
SOURCE: guitar hero world tour game has no sound all
check your disk for scratches or fingerprints.
Posted on Jun 11, 2009
SOURCE: Scratchy audio on XP SP3
This may help.
Posted on Jul 11, 2009
Car starts running rough at idle, eventually quits running. Has new plugs, wires, cap, fuel pump, fuel filter, air filter, IAC Valve, and gas cap.
Back then, Honda suggested timing belt replacement every 60,000 miles. If your Honda has that much mileage or more and has never had the belt replaced, now may be the time.
Sep 11, 2012 | 1995 Honda Accord
Cold start rough idle
If you replaced the plugs, did you replace the intake manifold gaskets if not, then replace them. They must be replaced every time the manifold is removed.
Nov 03, 2017 | 2007 Jaguar X-Type 2.0
Whenever I play the guitar through my TonePort UX2 there are lots of popping and crackling sounds, how can I resolve this?
More than likely your cable is old and should be replaced. Monster cables are a bit more expensive but come with a life time warranty, check em out. If the cable replacement doesn't work, check the sound card. Make shire it is not loose, or full of dust. It may be the sound card is old and needs to be replaced. Another option is the guitar itself. Try plugging it into an amp to make sure it doesn't pop. If it does the same on the amp, you have a problem with your pick ups or the cable connection to the guitar. Hope that helps.
Jun 12, 2011 | Line 6 TonePort UX2 Sound Card
How do i get the heavy metal sound that i want?
Try here for the info:http://line6.com/community/docs/DOC-4499
Jun 11, 2010 | Line 6 Spider Iii 120 Stereo Guitar Combo...
Sound
If your strings are old try replacing them, or cleaning them. You can clean them by boiling them or soaking them in denatured alchahol.
Apr 19, 2010 | Line 6 Variax 700 6 String Modeling Guitar...
A 700 series Line 6 Variax,noisy hiss
The hissing is caused by a bad connection, most likely at the cable jack. Try replacing it and while you're doing that check the rest of the components - especially the potentiometers, used ones generate a lot of static.
Jan 26, 2010 | Line 6 Variax 700 6 String Modeling Guitar...
I Actually have the line 6 ux2 and sound great but when i play the guitar make some clicks and/or pop and glitches and is freaking me out, i try reinstall, download the newest drivers, with no change in my...
i had the same thing- go to windows device manager and DISABLE you wireless connection. Even if you disconnected from the internet, the wireless cards job is to be aware of wireless signals and be prepared to connect. Once you are finished, ENABLE the wireless card.
Jan 12, 2010 | Line 6 TonePort UX2 Sound Card
Rough running and engine light is on. Sounds
try replacing the sparkplugs. u must be flooding fuel that needs to be well burned. try replacing the hi tensior wires too to be sure. hope this helps
Jul 06, 2009 | 2005 Mercury Sable
Amp turns on but no sound even with diff guitars and cords
Hi Dan
I wish I could just say what to fix, but you can not do this at home. Line 6 is a great amp and worth the time taking it down to the music shop , to be looked at an give you a repair estimate. good luck keep on rocking in the free world. DFD
Apr 12, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
After hour of playing the amp starts the effect popping sound
there is an open connection, most likely right off the input jack ,causing this issue. Resolder it or retension the jack connection.
Jan 29, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Computers & Internet Logo
104 people viewed this question
Alun Cox
