Question about HP Photosmart 3310 Printer
Photosmart 3310: unable to fax from Solution Center GUI
I have used the level 4 uninstall for a comprehensive uninstall of the 3310 s/w running on a HP a1730n w/ 4Gb RAM, Vista 32 Ultimate. I disabled all the firewall, anti-virus and other Symantec services, rebooted and installed the latest AIO_CDB_Full_Network_enu.exe from HP with no apparent problems. Used the Fax Setup Wizard with apparent success. However, when attempting to fax from the HP Solution Center, I receive an error message: The fax scan failed. Retry the fax. I retried several times with the same result. I went online with HP chat, and had the same result. I can fax from the 3310: I can scan from the 3310 as well as through the GUI; and I can receive faxes.
  • 3 more comments
  • Duane Andre Dec 09, 2007
    As stated in the last sentence, I can scan from the 3310 as well as through the GUI.
    I can scan and fax from the 3310, but I can only scan through the HP Solution Center graphical user interface (GUI) on my computer; however, I cannot fax using the HP Solution Center GUI.
  • Duane Andre Dec 10, 2007
    Thanks. Vista is quite fine, and apparently, it's not Vista that's keeping me from using the fax function from the Solution Center, it's HP's incomplete programming.
    I've read the readme files for the Vista installation of the Solution Center, and no where does it state that only "walk-up" is supported. HP took my contact info in case the level 2 support programmers find a solution for a recognized software problem.
  • Duane Andre Dec 26, 2007
    Previous advice was clearly insufficient.
    I have used the level 4 uninstall for a comprehensive uninstall of the 3310 s/w running on a HP a1730n w/ 4Gb RAM, Vista 32 Ultimate. I disabled all the firewall, anti-virus and other Symantec services, rebooted and installed the latest AIO_CDB_Full_Network_enu.exe from HP with no apparent problems. Used the Fax Setup Wizard with apparent success. However, when attempting to fax from the HP Solution Center, I receive an error message: "The fax scan failed. Retry the fax." I retried several times with the same result. I went online with HP chat, and had the same result. I can fax from the 3310: I can scan from the 3310 as well as through the HP Solution GUI on the PC; and I can receive faxes normally.
  • 790 Answers
Hello!!!
If u r using IE7 please uninstall it and try in IE6 ... seriously if u r pissed of that problem do give a try ...
GUD LUCK!!
Posted on Dec 26, 2007
  • HP Master
  • 1,113 Answers
When using HP Solution Center can you scan?
Posted on Dec 09, 2007
  • 5 more comments
  • Soulvisitor
    Soulvisitor Dec 09, 2007
    GUI?
    Have you a network setup fax driver as well as print driver?
    I do not know Gui sorry for my shortcommings but I do know the printer.
    I was asking if you could scan from same software you are unable to fax from HP solution centre, I have noted that you fax normally and print/scan.
    ie fax from the HP Solution Center, I receive an error ...I can fax from the 3310: I can scan from the 3310 as well as through the GUI
  • Soulvisitor
    Soulvisitor Dec 10, 2007
    I just found your issue .....PC control of Fax/Copy functions. The user must use the control panel on the device (walkup).
    Unavailable functions in the corporate solution
    The following functions from the full retail solution are unavailable in the corporate solution:
    · PC control of Fax/Copy functions. The user must use the control panel on the device (walkup).
    · Control panel Scan button. This button is non-operational with the corporate solution.
    · HP Photosmart. The HP Photosmart software is not installed with the corporate solution.
    · OCR software.
    · Product Tour and Registration.
    · Other software items, such as bundled software.
    Note: Your product might not include fax support.
    This you will find in the directory that you installed AIO_CDB_Full_Network_enu.exe as a readme file
    HP Photosmart/Officejet Corporate Readme
  • Soulvisitor
    actually the readme is listed under HP diectory that was created on install
  • Soulvisitor
    so I guess you really need to try to see if the full version supports faxing AiO_071_000_201_000_CDA_Default-Full_Network_AmericasEuro1.exe 1/1 (298.43M)
  • Soulvisitor
    sorry thats XP
  • Soulvisitor
    Vista LINK
  • Soulvisitor
    Maybe I'm wrong I am using XP versions as tests, no vista (thankgod)
I have an HP photosmart 3310 printer with an error message: INK SYSTEM HAS FAILED. UNABLE TO COPY, RECEIVE FAXES, OR PRINT. REFER TO PRINTER DOCUMENTATION. ERROR: 0xc18a0106 This comes on whenever I...
Why dont you try uninstalling this form your PC/laptop and reinstalling it again.
This should help restart the printer again.
Good luck and thanks for using Fixya
G.
Jun 14, 2011 | HP Office Equipment & Supplies
Ink system has failed. Unable to copy, receive
normally in this scenario the whole printer needs to be replaced..
Oct 22, 2009 | HP Photosmart 3310 Printer
Can't launch fax with HP solution Center
I'm having the same problem... did you ever fix it?
Jul 26, 2009 | HP Photosmart 3310 Printer
Faxing Hp Photosmart C8160 Solution Center Doesn't Work
This might be one of the communication error issues,
if your printer is connectd to your computer tower using the USB cable make sure that the cable is not too long and also it would be better if you are using the cable that came with the printer
also check if the printer is not connected to a surge protector,it should be onnected directly to a direct power outlet.
check if you do not have multiple icons of the printer in the control panel under printer nad faxes
check if you have the right tab chosen for the printer in the solution center.
try a semi full reset which is # and 3
AS you said that a paid hp support couldn't resolve it
i offer you a free technical support.
i have troubleshot HP all in Ones for 2 years and would like to help you with this...
Jun 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
Photosmart 3310 All-In-One - Cannot install..... Downloaded software from HP web site - 96% install it brings up a "FATAL ERROR" message and then uninstalls it. Running Vista - Help
Hi
The installation will get stalled at 96% , because due to 3rd party service running, will not allow to install HP printer driver.To resolved this follow below steps
1.Disconnect the Printer and uninstall the software.
2.Reboot the PC.
3.Click start, then in "start search" box type "msconfig"(without quotes).Click OK.
4.In System Configuration Utility, Under GENERAL tab, click on SELECTIVE STARTUP, Uncheck "Load System Services" and "Load Startup Items".Click on Apply
5.Then Click on SERVICES tab, at the bottom Check "Hide all Microsoft Services" and then click "Disable all".
6.Click apply and OK. Reboot the PC.
7.Now install the software.
Please let me know once you have done this.
Thanks
Rizwan
Dec 09, 2008 | HP Photosmart 3310 Printer
Cannot See Estimated Ink Levels on Printer Toolbox
Unplug the ethernet cable - wait a couple seconds - plug the ethernet cable back in - try again
Mar 18, 2008 | HP Photosmart 3310 Printer
Error HP Photosmart 3310. No strart print, no scanning...
I have a Photosmart C6180 all in one and get an error message 0xc18a0101 Ink System has failed. Unable to copy, receive faxes or print. Refer to printer documentation. Error: 0xc18a101.
I put new cartridges in and tried to recalibrate as mentioned by someone on the board. Can anyone help, please?
Nov 16, 2007 | HP Photosmart 3310 Printer
Printer problems for HP Photosmart 3310
Try running antispyware and virus program to eliminate this, housecall is online, thorough and free. It removes it too. Try and see if updating the actual drivers help off HP website. Check settings to see if it is not accidentally set to only print test page or to work offline or similar, uncheck tabs if they are.
Nov 10, 2006 | HP Photosmart 3310 Printer
HP Photosmart 3310 Printer Logo
319 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
