Question about Kenmore Washing Machines
How can I clean the softener compartment - it isn't working
  • 15,935 Answers
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Fabric softner will not when it reaches its cycel
Look Inside the compartment where you put the softener in. Above are holes where the water comes down into the compartment. They sometimes get clogged. Use a pick or q-tips to clean the holes. A temporary solution if that doesn't work, you will have to add softener manually into the soap compartment at the time when the softener should be dispensed.
Feb 21, 2016 | Whirlpool Washing Machines
Electrolux 1292 softener compartment not dispensing after few years
Good Morning Sandie,
I understand that you are having trouble with the softener dispenser not dispensing on your Electrolux washer. I suggest running a System-clean cycle on your washer, as well as taking out the dispenser drawer and taking the dispenser compartments out and cleaning them. It might be that the softener has built up inside the dispenser drawer. If that does not work, reset your appliance by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. If you are still noticing the softener not dispensing, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 09, 2014 | Electrolux Washing Machines
Salt container looks blocked with brown sludge. how do you remove to clean?
It's always a good idea to include the brand and model number of your appliance when requesting assistance.
Is this the "brown sludge" you're referring to?
This isn't sludge. It's the the water softener resin. The brown/orange colour is perfectly normal and is a good indicator of the water softener functioning correctly. You only need to worry if this turns black.
Aside from this, removal of the salt compartment / water-softener often requires major dis-assembly of the dishwasher and isn't a job I would recommend or advise on for anyone other than a professional - especially when there's nothing wrong with it ;)
Hope this helps.
Regards,
BElectric
Oct 17, 2011 | Dishwashers
My Hotpoint WML520P washing machine is working fine but the fabric conditioner is not draining and is staying in the compartment after the wash cycle has finished. I have removed the tray and cleaned the...
I hope you don't mind me saying so but often the softener dispensing siphon tube gets missed when cleaning the dispenser 'cos it's difficult to see!----------->
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this isn't the problem it could be that the water dispensing is not working correctly. It is easy to check by selecting (final?) rinse, pulling the drawer slightly out and seeing and hearing whether water is being fed into the softener tray. If is isn't then it is a call-out ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 07, 2011 | Washing Machines
Fabric softener doesnot seem to work
Open soap drawer and remove little 'hat' from it's post in the fabric softener compartment. Make sure both are clean and free of softener residue.
Mar 18, 2010 | Washing Machines
Compartment 3, detergent dispenser, fabric softener.
Grasp the drawer firmly, and give it a good tug to pull it out.
Remove all parts, and thoroughly clean, then just line it up with compartment and push it back in.
Plz rate my solution.
Thanks.
Jan 17, 2009 | Indesit W 123 Front Load Washer
Non-performing softener outlet
More than likely a blockage in the dispenser drawer,remove drawer, and thoroughly clean every part of it, particularly the condioner compartment and any removable parts in it, also clean any residue of powder or conditioner in the dispenser compartment..
Thanks.
Jan 10, 2009 | Tecnik TKL9290 Front Load Washer / Dryer
Excess water remains in detergent/softener compartments
the best thing that you can do is to pull the dispenser out and clean it. the softener works on a siphoning action and if it is a little clogged then it will not work properly
Dec 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Remove the fabric softener compartment for cleaning
open up and on the left side toward the back you see a little tab push it down pull out the dispencer
Mar 02, 2008 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
19 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
