Question about Electrolux EL5020 Vacuum
Stuck power cord - Electrolux EL5020A VacuumCleaner
I have a Electrolux EL5020A VacuumCleaner and the power cord is stuck. It will not move in or out. I ahve followed the instructions in post http://www.fixya.com/support/t1061517-change_cord_electrolux_el5020 to the point where the lft wheel should come off.I removed all of the screws, including the two next to the wheel but am not able to see how to remove the wheel.Any help would be appreciated.ThanksChris
4 Suggested Answers
  • 97 Answers
SOURCE: cannot access www.electrolux.com.au/register to register
This seems to be a problem with your web browser. If you're using Internet explorer, just click on Tools>Internet Options>Delete Files and try to access the website again.
Posted on Sep 18, 2008
SOURCE: change cord on electrolux EL5020
In order to get to the cord that is disconnected you need to remove the screws that hold on the frame(the red shell). You will need to remove the "fenders" that are near the wheels. In order to remove the fenders get a flat tip screwdriver and pry up on the front part of the fender, there are three clips holding the left one on and two holding the fender near the cord. You will need to remove the left wheel (the wheel farthest from the cord). After you remove all the exterior screws and the four screws under the brissels the shell should be able to be removed. Next you will need to pull the cord all the way out and there will be a clear clip, use a flat tip screwdriver and release the clip in order to remove the clear piece that holds the power cord electrical ends. Reattach the clips of the power cord and be sure when you put the clear piece back in that the two contacts are not bending. You will need to use a screwdriver to guide the electrical clips back into place. I didn't count the screws there is a lot of them. I hope this helps you
Posted on Oct 17, 2008
SOURCE: Electrolux EL5020A VacuumCleaner - taking apart
There are more star screws than you think. Under the cover over both wheels there are two on one side and one at the rear of the other. Getting the covers over the wheels off is a task. They are only snapped in but getting them out is a fluster. Also under the brush assembly are several screws. This thing is secured better than a tank. Good luck..Took me an hour to figure out where all the screws were located...
Posted on Jun 19, 2010
How to replace el8602a power cord
Electrolux Vacuum Cleaner EL 8602A How to replace the ...
www.manualsonline.com/.../vacuum.../how-to-replace-the-power-cord-o...
Question About Electrolux Vacuum Cleaner EL 8602A. How to replace the ... How toreplace the power cord on Electrolux EL8602A. Asked by gerry nickel on ...
Rewiring the Power Cord for the Electrolux Model G ...
? 4:27
https://www.youtube.com/watch?v=4uqNa7mVBO8
Jan 30, 2012 - Uploaded by Jayson1940D14
Rewiring the Power Cord for the Electrolux Model G ... How tochange the Electrolux 725 Suspension Plate - And Get Access To The Motor ... Brown Vintage ELectrolux Canister Vacuum Cleaner 1401-b - Duration: 0:17.
Electrolux Nimble Upright Vacuum, EL8602A - YouTube
? 3:49
https://www.youtube.com/watch?v=-anwdD4fK-o
Nov 11, 2014 - Uploaded by Michael Callender
Electrolux Nimble Upright Vacuum, EL8602A Best Price ... Dirt Devil UD70095 Power Reach Multi Cyclonic Pet Bagless Upright - Duration: ...
Jan 30, 2016 | Vacuums
C 153c how to dissasemble
Turn Body on it's top so bottom is facing up. Remove all screws around the perimeter of the vacuum. Turn vac over and slide entire top off of the body exposing the cordwinder. Voila!
It's probably just stuck! Hope that helps!
Jun 15, 2014 | Electrolux Guardian Bagged Canister Vacuum
Cord stuck all out
Lift the front of the vacuum so the canister is at about a 75 degree angle. Gently tug and release cord. It may take a few tries, but it usually works.
Jan 07, 2011 | Electrolux Guardian Bagged Canister Vacuum
My power cord will not retract back into the housing< i would like to open the back of the unit but there no screws or bults to due so. How do you open the back of model c151d
Try standing vacuum on end, then gently tugging and releasing cord. This generally will retract it.
There are many problems that can result in disassembly and reassembly by an untrained person, including shock and fire. For those and other reasons, I don't recommend trying this yourself. Take it to the nearest Aerus Electrolux store for repair.
The back of the vacuum can only be removed by separating the top and bottom portions of the canister. The cord winder will need to be removed and the wires all disconnected. The cordwinder is then taken apart and the cord rewound and set for proper tension for rewinding. If the cord is simply stuck due to having been pulled out too far, this is generally not necessary.
http://www.aerushome.com/storelocator/
Jan 07, 2011 | Electrolux UltraLux 2000 Bagged Canister...
these[ things] you talk about are called lock clips.with a little force and a small screwdriver they open be careful not to snap them, take your time as you move along; the lock clips will start to reveal themselves more openly again take your time ,after the casing is opened it should reveal the electrical cord.;before you start this procedure make sure the electrical cord is unpluged from the power supply hope this helps you.adrian
Feb 16, 2009 | Electrolux EL5020 Vacuum
Metal hanger stuck in central vac hose
there should be a pin push it in then pull out power head then try to pull out hanger
Feb 08, 2009 | Electrolux Central Vacuum
Cord is stuck out full length
Not sure if you're posing about the Hoover since you're in the Hoover S1361 forum, or the electrolux.
I had similar frustrating problems with my hoover and made a blog post on how to take it apart and fix it here.
Jan 18, 2009 | Hoover S1361 Bagged Canister Vacuum
The roller brush will not stay on-& the cord rewind is stuck on
There is a reset on the power head, does the wand fit tight in the neck of the power head, if not you may have a problem there, either the wand or the neck. If the lever is stuck on, then it is jammed or broke, maybe a spring is out of place, in any event the canister will have to be taken apart to see what the problem is.
Feb 19, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux EL5020 Vacuum Logo
46 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
