Question about General Electric E850 Digital Camera
My camera is jammed and wont move
My camera is jammed and wont mov. The outer lens will not move back into the camera nor will the shutter close
My camera is taking black images, and lens erroring. If anyone can help, it would be greatly appreciated.
Your suggestions won't work and there are no DIY fixes on cameras, especially with as many problems as yours has after dropping it. The screws are tiny and you have to disassemble in the correct order. Once you get it apart, you won't have the spares to fix the bent pieces, and then you need to put it all back together in the correct order. You need to get it professionally repaired. Although the camera is old, it is a good camera and worth getting repaired.
Jun 08, 2016 | Nikon COOLPIX L820 Digital Camera Black
My camera says..lens error will shut down automatically restart camera..! so my lens wont close even when i turn my s100 on or off. please help???
Make sure there is no dust or foreign material that could be jamming the lens and lens shutter. Have you tried removing battery or battery pack or try to reset camera? Just a suggestion.
Oct 02, 2013 | Canon PowerShot S100 Digital Camera
Lens gets stuck,and makes a clicking noise when trying to open
Hi
Thanks for using FixYa. With the camera closed and off point it straight up (lens towards the ceiling) and hit the power button while holding down the shutter release. When the camera opened, it immediately tried to focus for the picture it was told to take, and apparently it forced the lens to move.
You can also try blowing compressed air around the lens cover to clean it. Now slide a thin strip of paper between the lens cover shutters and the outer support ring and move it around 360 degrees. This will clear the debris stuck there.
With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat these steps several times to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 04, 2010 | Samsung S1050 Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
My son pulled out one of the shutters that opens and closes over the lens. The shutters no longer open all the way. The camera is brand new. How can I fix the rest of the shutters? Should I pull them...
You can pull off the other one if you want. To put it back in your basically going to have to take apart the camera. The "Shutters" on the outside is nothing more but to protect the lens will its in the camera. The actual shutter is inside the lens that open and closes very quickly when you take a picture.
Think of it this way, the shutter in the lens opens up to let in light that shows the image to the sensor behind the lens. Then it closes to "finish" capturing the light".
The "shutters" or "doors" on the outside do not move once you take a picture. They only close once the lens retract. (When the camera is turned off or idles)
Hope this has been helpful.
Mar 30, 2009 | Fuji J150w Digital Camera
When i take pictures, sometimes they come out with lines all over them.
shutter problem. put camera into full optical zoom, turn it to face you and angle it so that you can see into the lens without reflection. In full zoom the internal lens is right up to the outer lens so, even on a small lens such as this, when you press the picture button you should see the shutter close across fully. If it does not you will get either an over exposed or complete white out picture. Or lines across your pictures.
The shutter needs to be cleaned. There is grease in the camera for the moving parts and is probable that this is the cause for the error.
I have found this to be the case for fuji's E900, E550, F40fd, F470, F460, and a few samsung's as well.
Mar 08, 2009 | Fuji FinePix A400 Digital Camera
Nikon FM10 shutter wont deploy with lens on.
Check the lens. Does the diaphragm move freely when you move the f/stops? Put the lens on f/8 or f/16 and push the pin in, it should move freely and close to the f/stop you set. If not the blades may have oil on them. Also if it is free then set the lens to the smallest aperture and if there is a button push it in to lock for auto aperture set.
Dec 06, 2008 | Nikon FM10 35mm SLR Camera
Film advance lever wont move. Shutter button does not register.
the self timer may be the issue. the self timer if not all the way released will not allow you to advance to the next frame :( i sometimes have to push it back to the start position
Nov 13, 2008 | Photography
When powered up, "Remove lens cover, press button"
The symptom of "remove lens cover" always showing can be caused by two different things. If the lens assembly has become jammed and will not move when the camera tries to extend it - this can cause the message. On some cameras a stuck-closed shutter can cause this message as well. The symptom you describe of seeing two images prior to the failure is strange. I cannot make any kind of conclusion from that information without further elaboration. Does the lens extend when you turn the power on? If not the lens is jammed. Do you see nothing but black all the time on the screen and the captured photos? If so the shutter is stuck closed. Either of these problems will require complete disassembly and re-setting of the lens elements. Check with your manufacturer and see if they will fix it under warranty. If not, there are service providers available on the internet who can service your camera. David Millier Advance Camera Repair
Feb 27, 2007 | Panasonic Lumix DMC-FZ5 Digital Camera
General Electric E850 Digital Camera Logo
103 people viewed this question
Top General Cameras Experts
JOHN ALBURY
JOHN ALBURY
Are you a General Camera Expert? Answer questions, earn points and help others
