Question about ViewSonic VX710 17" Flat Panel LCD Monitor
Will not come on. I have checked both the cables (power and computer)and they are ok. When pressing the power button the green light in it flickers slightly but monitor will not come on.
  • 916 Answers
Remove the cable from the back of the computer with the monitor and computer turned on. If it gives you a no signal error either the cable or your graphics card inside the computer needs to be replaced.
Posted on Sep 07, 2009
How can i fix error 5200 on my canon pixma ip2770
You can try the following 1. Turn off printer, cable power still plug in,
2. Press Resume Button don't release
3. Press Power Button don't release and than release Resume Buttons
4. Press Resume Button 6X
5. Turn off printer cable power still plug in
6. Turn on printer again, now this printer ready to use.
Or try
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready to use
Jul 27, 2011 | Canon Office Equipment & Supplies
Tip
My moniter is blank
Solution :
  1. Make sure that monitor is turned on. try pressing the power button on the monster again.
  2. check to see if it is in the sleep mode. wiggle the mouse around or press the enter key.
  3. if the green light is not on in front, check the power cord connecting the monitor into the outlet
  4. if green light is on check the brightness level by using the bottoms in the monitor.
  5. check the cable connection from the computer to the monitor. and also check the connections in the other equipments connected to the computer for example TV
  6. if you still have a problem, call your help desk.
^_^
on May 08, 2010 | Computers & Internet
Monitor will not stay on
Generally Monitors have a single light in fron pannel, with dual mode colors as Green and Orange.
Green: Everything is OK .
Orange: Everything is OK, except it is not getting
any signals from computer or other source.
Try with any other monitor with your CPU, it may happen that CPU actually not providing any signal to Monitor. Try checking the "NUM LOCK" button on and off, whether it makes the light on keyboard to flash on or off.
If NUM LOCK is woking OK, there is surely some problme with your monitor and you need to get is checked physically with an engineer.
Jan 21, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
WHEN I PRESS POWER BUTTON NOTHING HAPPENS
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard. GOOD Luck.!!
Aug 27, 2009 | Insignia D400a PC Desktop
Computer will not power up.
Check the fuse, if thats ok then try this -
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Jan 18, 2009 | Computers & Internet
Supertooth one user manual
Charge your Supertooth one via the car charger or by attaching a usb/mini usb cable to your computer usb port. Need to charge for 4-10 hrs. Indicator light glows red (needs charging), orange (charging) or green (charged)
Power on: Press green button for 1 second. Indicator light blinks blue. A beep will be heard
Power off: Press green button for 1 second. Indicator light turns red. A beep will be heard
To pair with your mobile phone:
1. Press green button on Supertooth for 5 secs until indicator light blinks red/blue 2. Access bluetooth menu on your phone. Turn bluetooth on. Execute a bluetooth search. 3. Select ST ONE from list 4. When phone requests password enter 0000 and press OK 5. The handsfree kit is now ready for use 6. Clip Supertooth on sun visor of your car so that the microphone and control buttons are directed towards you.
To make a call: Dial number on phone. Supertooth will automatically connect. Indicator light is steady blue during call
To end a call: Press red button for 1 second
To answer a call: Press green button for 1 second. The bluetooth indicator will turn a steady blue.
To increase/decrease volume. Press volume buttons repeatedly up or down. They are situated between red and green buttons.
Hope this helps.
Nov 22, 2008 | Cell Phones
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
PC boots up, but no display and hard drive does not seem to spin
I strongly suspect that you have a bad connection to the hard drive, since you were moving it in and out.
Check power connector on HDD and make sure data cable sits in OK and that data cable is not reversed.
Rudolf
Dec 05, 2007 | Computers & Internet
Blank Screen, power light is steady green
have you tried adjusting for the brightness and contrast of the monitor. does any menu comes out if you press any buttons of the monitor except power of course!
Nov 16, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Canon i350
http://startcopy.ru/repair/can_s_ip.htm
Nov 08, 2007 | Canon i350 InkJet Printer
ViewSonic VX710 17" Flat Panel LCD Monitor Logo
122 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
