Question about Network Computing Devices (NSH800S/A) Networking Switch
Power Surge On Hub Port eery time i try to connect my MP4 SD-2415
Eerytime i connect it to my computer that pops up..on all 3 of my computers what can i do?
  • Ricky Tracey May 11, 2010
    You need to provide more info. It sounds like you are connecting something to a PCMCIA slot which may also require an external power source. Confirm that you are talking about PCMCIA (Laptop card) or if it's something else.
  • 32 Answers
When it gave popup option then click continew
Posted on Sep 19, 2009
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
We bought my son an RCA mp3 player yesterday (TH1814-A). We inserted the battery and are trying to plug it into my desktop using the usb connector so that we can upload some music. however, when i plug...
There are different types of USB port. For instance my computer has two types. One with a blue connector and one with a black connector. It might be that your USB ports are not suitable for that device. You need to check the specifications of the USB ports on your computer and the specifications of the MP3 player. Continuing to use the device might cause damage to the computer.
Mar 19, 2017 | RCA Audio Players & Recorders
WD 500 g Passport Power Surge
The power surge error means that your external drive is drawing more power than your USB port can supply. The best solution is buying a powered usb hub (USB hub with external power source) and connecting the device through that.
Alternatively (if you're desperate), you could try testing it in other ports - for instance, if you're using it in a front USB port, try the back ports and vica-versa. If you need something on the drive urgently, and you have the option, you could always try plugging it into another computer and getting the data that way, but of course this is only a temporary fix.
The fact that the drive is in a NTFS/FAT32 format shouldn't make a difference with regards to the main issue, which is power....but like I said, your best solution is unfortunately to buy a powered hub and running the drive through that.
Good Luck,
-LL
Feb 23, 2010 | Electronics - Others
Power Surge on Hub Port
Don't Use existing USB Portn On your Comp if u want USB port then install PCI USB Card From the PCI USB card you can use your USB Device what ever you want to use
Thanks
Ankur
May 29, 2009 | Compaq NX6110 TFT XGA Notebook
Some USB devices draw excessive power from the USB port, especially USB scanners. When this happens you need a powered USB hub, connect this to your computer's USB port and connect the USB device into the powered USB hub, you should not have any further error power surge problems.
Apr 27, 2009 | Compaq NX6110 TFT XGA Notebook
Error power surge on hub port
Some USB devices draw too much current from the computer's USB port and you get an exceed power error message.
To get around this problem, get a powered USB hub and connect it to the Computer's USB port and then connect the troublesome USB device into the powered USB hub.
Apr 09, 2009 | Lenovo 3000 N500 Notebook
Error message "power surge on hub" when attempting to upload from N C 5200
Hi, are you using a USB hub or attaching directly to the computer USB port?
  1. If you are using a USB hub, which is then connected to your computer ... you either need to
    1. Plug the camera directly in to the computer so that the computer supplies the USB with more power to the camera.
    2. If the USB hub has a power plug/adapter, use it so the USB hub gets more power to handle the task.
    3. Buy a different USB hub that has a power adapter so enough juice can be supplied to the tasks that USB is asking to do.
  2. Some USBs on the computer aren't giving enough power, you may have a bad USB port, try another one.
  3. Use a Card Reader, which is much faster to download pictures than from the camera.
Reason: some times, the USB task is asking for a lot more power than is being supplied through the current USB path. You have to either add power through an adapter or plug directly in to a power source (like the computer directly, or a reader that doesn't require as much power to operate it).
This should help, if so, please mark as FixYa!
ThankYa!
Dec 01, 2007 | Nikon Coolpix 5200 Digital Camera
Power Surge error message
I guess that this could be your error message:
"Error message when you wake up a Windows XP-based computer from hibernation or from standby: "Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port"
If it is the case, please try below solution:
SYMPTOMS
When you wake up a Microsoft Windows XP-based computer from hibernation or from standby, you may receive the following error message:
Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port. This error message is displayed even if there are no USB devices connected to the computer.   WORKAROUND loadTOCNode(1, 'workaround'); To work around this issue, disable the USB 2.0-enhanced host controller.
Note When you disable the USB 2.0-enhanced host controller, you lose USB 2.0 functionality. That is, you revert to USB 1.1 functionality.
To disable the USB 2.0-enhanced host controller, follow these steps: 1. Right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. In the Device Manager pane, expand Universal Serial Bus controllers. 4. Right-click the USB 2.0-enhanced host controller, and then click Disable.
Note The name of the USB 2.0-enhanced host controller may vary. 5. When you receive the confirmation message, click Yes. 6.
Close Device Manager.
I hope that this should resolve the issue for you.
Please let me know the result.
you can mail me at thumuvikram@rediffmail.com for any further assistance on this issue.
I'll be glad to help you.
Oct 18, 2007 | IBM ThinkPad T43 Notebook
Power sugre with m240
Hi there. This message would indicate any one of the following: 1. You have a lot of USB devices plugged in to your computer, and the maximum power supply for the USB ports has been exceeded by plugging this player to your computer. It would be best if you unplugged 1 or 2 of the USB devices connected for the time being. 2. You are plugging the player on your front USB port, and may need to plug it in the rear USB port to acquire ample power supply (front USB ports do not get as much power as the rear USB port -- sad but true) 3. You are using a laptop and may need to try another USB port on that computer. Purchasing a self-powered USB hub would be ideal as it gets its power supply directly from the wall electrical socket.
May 11, 2007 | SanDisk Sansa m240 MP3 Player
Network Computing Devices (NSH800S/A) Networking Switch Logo
80 people viewed this question
Top Network Computing Devices Computers & Internet Experts
1860ph
Level 1 Expert
Michael Terence...
Michael Terence...
ray gallant
Are you a Network Computing Devices Computer and Internet Expert? Answer questions, earn points and help others
