Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
Switch on problem with samsung lcd tv - Samsung LE40R73BD 40 in. HD-Ready LCD Television
  • Ken Pawley May 11, 2010
    what is the problem exactly,is it makin a clickin noise,and was it takin longer and longer to come on?.
We have to push the on button on our TV from 20-100 times to get it to turn on. Have changed batteries and restarted to no avail.
"He said our TV has a problem". Brilliant! To be more specific, he could have suggested switch failure or a failing power supply.
Apr 26, 2017 | Samsung Televison & Video
Samsung LCD... Power supply, t-con or inverter?
Samsung LCD TV Repair - TV Won't Turn On - How to ...
? 8:22
https://www.youtube.com/watch?v=n54IurMvr6o
Apr 4, 2014 - Uploaded by ShopJimmy.com
So in this video today we are going to be looking at a Samsung LCD and how to diagnose if you have a bad main or a bad power supply.
Samsung LCD TV Fixing Power Supply Problem - YouTube
? 10:52
https://www.youtube.com/watch?v=F6qgCg8lsxc
Dec 23, 2011 - Uploaded by Studio G Vision
Samsung LCD TV Fixing Power Supply Problem. Studio G Vision .... How switch mode power supplies (SMPS) work - Duration: 19:22.
Samsung LCD TV Power Supply Repair, Capacitor Replace ...
? 25:23
https://www.youtube.com/watch?v=lL0id3-YZsQ
Feb 9, 2013 - Uploaded by HandySavesMoney
... LN46A630 LCD TV. This procedure will apply to several otherSamsung TVs. ... Samsung LCD TV Power Supply Repair, Capacitor Replace, LN46A630. HandySavesMoney .... Country: Worldwide; Restricted Mode: Off.
Jan 27, 2016 | Samsung Televison & Video
Ns LCD 26-09 TV not powering up
LCD TV repair - Samsung LW20M21CP not powering up ...
? 25:30
https://www.youtube.com/watch?v=zxqDLDNuCfw
Jul 8, 2013 - Uploaded by RetroGameModz
This is a documented repair of a Samsung LCD TV that I got for cheap. It was listed as not working, which is ...
? 8:23
Samsung LCD TV Repair - TV Won't Turn On - How to Replace ... or if you have standby and the TV will ...
MOST COMMON REPAIR FOR LCD - NO POWER - YouTube
Dec 02, 2015 | Insignia NS-LCD26-09 26 in. HD-Ready LCD...
Samsung LCD TV backlight switched off
Most likely you will need to get a diagnoses done on the set. It could be a faulty 24vdc circuit (power supply capacitors), defective inverter, or a failing CCFL backlamp.
Oct 28, 2012 | Samsung LE-46A566 46 in. LCD TV
Makes clicking sound without switching on
is this a samsung? if so call them. its a well known fault on samsung lcd tv's. 0330 7267864 they should fix it for free. just explain your tv just clicks away when you switch it on.
Jul 31, 2010 | Samsung LA40R81BDX 40 in. LCD TV
My samsung lcd tv is lock on tv channels only
Check function buttons. One may be stuck. Disconnect the function switches from the switch board. If you can change inputs with the remote then replace switch board or switches. if not then replace the main board.
Mar 25, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
I VE A SAMSUNG LCD TV/MONITOR SNYCMASTER 932 19
can you see that a capicitor 820/10v is pluked ? replace it.
Feb 21, 2010 | Samsung SyncMaster 932B LCD Monitor
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
296 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
