Question about Kenmore Washing Machines
I have a Kenmore Elite 110.26962502 and need to remove lid.
I have a Kenmore Elite 110.26962502 and need to service the lid switch. I keep reading to "simply" remove the end caps from the control panel. Can't get them off. Removed the retaining screw from the back but won't budge.
  • Sherry Carriker Apr 10, 2012
    On my kenmore elite, after removing the 3 retaining screws that were visible from the back of the machine, I had to reach under the lid and pull/squeeze the brass clips to "release" the cabinet from the back panel. ( others show "popping" these clips using a flat blade screwdriver after flipping the control panel out of the way) My control panel did not "flip" up out of the way. It is secured with two more clips that are only accessible once you have the cabinet separated from the back panel. This little tidbit of info would have been greatly appreciated! My problem was the lid "safety" switch. I bypassed it entirely by connecting the two wires(not the green ground) with a wire nut and some electrical tape. I know others recommend against this. However, as I am the only one to operate my machine, I know to push the knob to stop the machine from washing or spinning should I need to. Also, on the plus side, did not have to buy any parts that would have eventually broken again.BUT BEST OF ALL, I NEVER HAVE TO SLAM MY LID AGAIN!!!
  • Kenmore Master
  • 8,220 Answers
Once those are removed you flip up the whole control panel. You do not remove the end caps on that particular washer. Here is some PICTURES
Posted on Sep 07, 2009
Kenmore elite top ?oad washer f84 error code
f84 Indicates the lid cannot lock.
Check for items caught in the lid keeping it from closing completely.
Is soap, fabric softener, or anything else keeping the lock from extending into the lid?
The control detects an open lid switch, or cannot determine if the lid is locked. Test the lid lock connection to the washer's control board and lid lock resistance levels.
Press PAUSE/CANCEL once to clear the code
Dec 02, 2016 | Kenmore Washing Machines
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
We need to replace the lid switch on a Kenmore Elite Washer...how do you do that?
Look on the back side of your control panel.Remove the screws from that panel you will find documents about your Kenmore..
Sep 17, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore top load washer (110-22642100) that will fill, agitate through entire wash cycle, but that's it.
HI THERE, IT SOUNDS AS IF YOUR PUMP IS BLOCKED, NOT WORKING OR SOMETHING MORE SERIOUS. START BY CHECKING THE PUMPS IS NOT BLOCKED, LOOSE CHANGE NORMALLY CAUSES THIS AND IS RELATIVELY EASY TO FIX.
Finding the pump on the Kenmore Elite top load washer is a fairly easy project that can be done in about a half hour. The Kenmore Elite is part of the GE line of appliances and shares many of the same interior mechanical parts and systems. The Kenmore Elite is a very streamlined exterior cabinetry design, but the interior can be accessed by removing just a few screws in order for you to locate the water pump.
things you'll need:
  • Screwdriver
    • 1
      Unplug the electrical cord of the Kenmore Elite top load washer from the electrical outlet before attempting to locate the pump.
    • 2
      Remove the end caps on the control console of the dryer by pressing in on the caps with your thumbs and pulling the caps forward to unfasten them.
    • 3
      Unfasten the screws on the ends of the control console in the front with a screwdriver and tilt the console back so that it rests on the back hinges.
    • 4
      Unplug the top lid switch from the rear of the lid that sits underneath the control console, pulling the switch straight up off the metal prongs by hand.
    • 5
      Pry the metal clips that sit on the top lid up with a screwdriver, lifting the clips to unlatch the top and pull the top lid cover off the washer base, setting it aside.
    • 6
      Locate the water pump at the base of the washing machine on the top of the motor shaft.
    • 7
    • take the cover off the pump and remove any blockage or debris.
thanks and good luck
iain
Read more: How to Find the Pump on a Kenmore Elite Top Load Washer ' eHow.com http://www.ehow.com/how_6304872_pump-elite-top-load-washer.html#ixzz1LQ4bdiFZ
May 04, 2011 | Kenmore Washing Machines
My washing machine fill up but no longer starts unles you bang on the lid. Now it won't even work doing that.
The lid switch is likely faulty and will need to be replaced. You can get one from partselect website or repairclinic website. I recommend partselect. If you desire, you can test the switch with an ohmmeter in ohm position. Should have infiinity reading with lid closed and no reading while open.
May 14, 2010 | Kenmore Elite HE4 Electric Dryer
I have a top load Kenmore Elite Washing machine that runs for 5 seconds then stops for several minutes. This pattern repeats. It just started yesterday. What is wrong with it? I have unplugged and...
Sounds like the timer is faulty. Or you lid switch is out of wack. Try leaving leaving lid open and placing a screwdriver in switch located where the lid clip comes down into washer. If this works the switch will need replaced. Timer is another story as you will have to remove top panel and replace timer if the lid switch is not the cause
Mar 23, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore elite 100.24942301 Lid switch problem
You may can slightly bent the part the lid contacts so it will be depressed further thereby making the switch. If that doesn't work then you will need to replace the switch.
Dec 29, 2009 | Washing Machines
Kenmore top load washer- have to bang lid several
This is most certainly caused by a faulty micro switch on the lid. Have the switch checked out and replaced if need be.
Best wishes,
Graemevm
Jun 06, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Says lid and won't work
Check the lid switch... sometimes if something heavy or someone sits on the lid, it can tweak it just enough so the lid switch loses contact and will keep the machine from turning on. You can sometimes bend the lid back. Check the lid switch by sticking a credit card between the lid and the switch with the lid closed... does that solve it? let me know.. KEN
May 08, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Washer kenmore elite calypso 21086
promblem with the lid switch is it happing durning the drain spin cycle
Jan 20, 2008 | Kenmore Elite 21086
Washing Machines Logo
390 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
