Question about Gateway P-6860FX Notebook
Hi, I have a 17" gateway P-6860,recently the lcd started blinking, the screen dims out and then comes to normal (making a blinking effect). I've changed the inversor but it still the same, i'd appreciate your advices about my problem, thanks.
  • 916 Answers
When this starts to happen it means the back light is on its way out and needs to be replaced.
Posted on Sep 07, 2009
My laptop screen went very dark, I can barely make out whats on the screen but I know its working. What can I do to fix this situation on my gateway p-6860fx pc notebook?
Hi josue fernan...
You need to see if your laptop lcd screen is faulty and/or the lcd inverer is faulty.
1....Test the lcd screen:
Hook your laptop to an outside monitor and then start your laptop normally...if the picture on the external monitor is good, then your lcd screen is bad.
2....Backlight Faulty: If the monitor is still as dark like your lcd screen on the laptop then it could be the backlight that is faulty.
Please take time to rate me thumbs up
LCD Backlight and Screen Replacements:
http://www.laptopsman.info/0-Gateway-lcd-1.html
LCD Screen replacement:
http://www.screentekinc.com/Gateway_P-6860FX--17-inch--1440x900-wxgaplus-laptop-lcd-screen.shtml
Sep 11, 2011 | Gateway P-6860FX Notebook
My FPD1976W Gateway monitor will display for only 2-3 seconds then go black. I can turn monitor off then back on it will display for 2-3 seconds then again go black. Start button is not blinking. Does this...
You've got it, one of the circuit boards has one or more failed capacitors.
If you decide to take it apart, check for capacitors with either a bulging top or a yellow stain underneath on the board itself.
Befored taking it apart, because you will, even if just slighty, damage the screen case, check your warranties. I had one pop recently, it had a 3 year - return to base warrany.
Jul 13, 2011 | Gateway FPD1976W LCD Monitor
The LCD screen on my Gateway M-6317 is dim. How
Press and hold the 'FN' key and tap the key that has the picture of a sun and an up arrow (or some other similar picture that dictates brightness - there should be two different keys that affect brightness one to increase and the other to decrease). Once you have the brightness set to your liking quit tapping the 'brightness' key and release the 'fn' key
Sep 29, 2009 | Gateway MX6447 Notebook
My Dell flat panel monitor flashes on and off what can i do to fix it...
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 14, 2009 | Gateway FPD 1730 17 in. Flat Panel LCD...
Laptop screen illumination
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Nov 03, 2008 | Gateway SL9550-30165318 Notebook
GTW-L17M103 LCD TV
perhaps a computer repair shop .
Dec 11, 2017 | Gateway LCD17TV 17 in. Television
HP w17e monitor
buy a new computer
Mar 13, 2008 | HP w17e Monitor
Monitor picture blurs out and dimming
Hey there chel wjd, My first guess is that your video card is faulty. I suggest you pull it and return your video connection to the onboard port. Ensure you make the necessary setting changes in the bios. If this solves your problem, get yourself another video card. Good Luck!
Jan 31, 2008 | Gateway FPD2275W LCD Monitor
Dark scree
I too have the same problem with the same monitor.. tv looks great OSD looks great.. pc is dim.. This has nothing to do with the inverter board or the backlight.. I believe that there is an issue with the components that render the Computer video.
Jan 17, 2008 | Samsung SyncMaster 17" TFT LCD Monitor
Gateway P-6860FX Notebook Logo
182 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
