Question about JVC Everio Share Station DVD Burner Burner
Same problem. "Disc is not compatible."
Can't find a solution.
    Problem Solver:
  • 17 Answers
I had the same problem and I tried DVD-RW 4X only yesterday, it worked perfectly......i intend to try DVD-R 8X and see what happens.
I read on the internet that the read and write speed of the burner is no more than 10X.
I guess they should have noted that in the manual.
Posted on Sep 08, 2009
  • wayne james Sep 10, 2009
    8X and 16X worked as well.
Wii cinsole does not read disc
Check for scratches on the disc. make sure it is compatible with the wii console that u are using. If your console is a PAL version make sure the disc has PAL written on it if not then its not compatible with it. Then it may be only the disc then take it back where you bought it from with the receipt and exchange it for another one.
Dec 31, 2011 | Nintendo Wii Console
Dvd/cd is not working
You can follow these methods to try to isolate and resolve the problem. Use these methods in the order in which they are presented.
Method 1: Clean the disc
When you have problems with a CD or DVD drive, always check the disc first to see whether it is damaged or dirty. To clean the disc, follow these steps:
1. Remove the disc from the drive.
2. Clean the disc with a disc cleaning kit or by gently wiping the silver side of the disc from the center outward with a dry, soft, lint-free, cotton cloth.
Note Do not use a paper cloth, and do not use a circular motion to clean the disc. These can scratch the disc.
3. Reinsert the disc in the CD or DVD drive.
If the computer can read the disc, you are finished.
If the computer still cannot read the disc, go to step 4.
4. Try again to clean the disc by using a cloth dampened with water, or dampened with a commercial CD or DVD cleaning solution.
5. Dry the disc thoroughly, and then reinsert it in the CD or DVD drive.
6. If the computer can read the disc, you are finished.
If the computer still cannot read the disc, go to method 2.
Method 2: Check the disc for damage
If the disc is clean, check whether it is damaged. To do this, follow these steps:
1. Remove the disc from the drive, and then examine the disc for scratches or cracks.
2. If the disc is damaged, try another disc to see whether the CD or DVD drive can read it.
3. If the computer still cannot read a disc, there may be a problem with the drive. Go to method 3 to troubleshoot the CD or DVD drive.
If the computer can read the other disc, there is a problem with original CD or DVD. Contact the manufacturer of the damaged disc to obtain a replacement.
Method 3: Try a different disc drive
If the disc is clean and undamaged, check whether there is a problem with the drive. To do this, follow these steps:
1. If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc.
If your computer does not have more than one disc drive, you can insert the disc in a different computer.
2. If the other CD or DVD drive can read the disc, there may be a problem with your CD or DVD drive. Go to method 5.
If the other CD or DVD drive cannot read the disc, the disc may not be compatible with the drive. Go to method 4.
Method 4: Make sure that the disc is compatible with the drive
Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive.
* A DVD disc is incompatible with a standard CD drive.
* A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs.
* A DVD disc is incompatible with a drive that does not have a DVD logo on the front.
If the disc is compatible, go to method 5.
If the disc is incompatible, use a compatible disc or contact the vendor for a compatible replacement.
Method 5: Use Windows Update to check for updated drivers
If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing.
Good luck
Jan 21, 2011 | Computers & Internet
I have had to replace my hard drive on my pc how can i get my music back on to pc from my ipod and back into i tunes
Backing up your iTunes library to a CD or DVD To burn a CD (CD-R or CD-RW), your computer must have a compatible CD burner. To burn a DVD (DVD-R or DVD-RW), your computer must have a compatible DVD burner. Check in iTunes Preferences to see if a drive is compatible. See below for steps.
To create your backup disc
  1. Choose File > Library > Back up to Disc.
  2. Select the option you want from the resulting dialog and click Back Up.
  3. The two options you can select from are:
    • Back up entire iTunes library and playlists
    • Back up only iTunes Store purchases
    Whichever of these two options you choose, note that you can also choose "Only back up items added or changed since last backup" to perform an incremental backup.
  4. Insert a blank disc (CD or DVD) into your computer's optical drive. iTunes will scan the disc and begin burning.
  5. Note: If the disc you insert does not have enough space to hold all of the content you will be backing up, a dialog will appear asking whether you wish to backup to multiple discs. You can click Data Discs to continue.
iTunes burns the number of items that fit on one disc and then asks you to insert subsequent discs to continue burning the remaining files. Don't eject a disc while a backup is in progress.
Spoken programs purchased from the Audible.com website are not backed up.
Discs you create using the iTunes backup feature can be used only to restore; they can't be played in a CD or DVD player.
Restoring from a backup disc
  1. Open iTunes.
  2. Insert your backup disc.
  3. iTunes will ask whether you want to restore from this disc. Click Restore.
Check drive compatibility
  1. Choose a playlist on the left side of the iTunes window.
  2. Click the Burn Disc button on the bottom right corner of iTunes.
  3. If the drive is listed, it's compatible.
Aug 16, 2010 | Apple iTunes
Cd burner saysinsert a blank disc, even after I do, can't burn cd
The disc must not be compatible. Check the manual for compatible disc list.
Nov 23, 2009 | Pacific Digital X-treme 52 (TREME52)...
Ps3 not recognizing disc is loaded and disc symbol does not appear on menu
Make sure that disc is cleaned, if you have an lens cleaning disc then run it. Depending on which system that you have...not all PS2/PS1 disc not compatable with PS3. Make sure that you have the right one if running an PS2 disc or check the compatability chart with Sony to see if that game can be played with your verision. The new slimmer PS3 unit are not compatible with PS2 disc which is wy the price is cheaper because they don't have the software/hardware added to play those games.
PLEASE VOTE IF THIS IS HELPFUL. GOOD LUCK AND THANKS.
Oct 31, 2009 | Sony Playstation 3 (PS3) Console
DVD plays OK on computer but not on Sony DVD player
It must not be compatible with you player.
Refer to your manual.
Robert
Oct 12, 2009 | Sony Televison & Video
I have magnavox vcrdvd combo every time put a disc in it say disc error
Check your disc compatibility. This is usually cause from not using compatible disc. A disc written on a unit not compatible. Most VCR DVD combos work great with DVD -R. Best DVDs to use, Sony and Maxell. Let me know if you have any other questions.
JimmyC
Sep 25, 2009 | Philips Televison & Video
Drive can not read CDs..read Dvds
I suppose that you have windows XP. Pls follow these steps Clean the disc - Clean the disc with a disc cleaning kit or by gently wiping the silver side of the disc from the center outward with a dry, soft, lint-free, cotton cloth. Check the disc for damage - Remove the disc from the drive, and then examine the disc for scratches or cracks. Try a different disc drive - If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc. If your computer does not have more than one disc drive, you can insert the disc in a different computer. Make sure that the disc is compatible with the drive -Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive.
  • A DVD disc is incompatible with a standard CD drive.
  • A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs.
  • A DVD disc is incompatible with a drive that does not have a DVD logo on the front.
Use Windows Update to check for updated drivers - If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing. To check for driver updates that you can install, visit the following Microsoft Web site: http://windowsupdate.microsoft.comRegards
Jun 18, 2009 | Computers & Internet
LITEON LVW 5024G make the disc compatable with other DVD players
This is how I do it:
Push the Guider button and go to finalize disc.
Jan 27, 2009 | Lite On LVW-5005 DVD Recorder
RAM compatability
The clock speed on the 5300 is higher however when installed with a 3200 the 5300 will "clock down" to the 3200 speed.  They are both compatible in this situation.
Dec 11, 2008 | Computers & Internet
JVC Everio Share Station DVD Burner Burner Logo
Top JVC Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Tre Elkins
Are you a JVC Computer and Internet Expert? Answer questions, earn points and help others
