Question about Toro Lawn Mower With Toro Power Tools
Pouring out oil.
It runs but is pouring out oil.As soon as oil is added it leaks out almost as fast. can this be fixed?
  • Toro Master
  • 8,404 Answers
Where is it pouring out from? Might you be over filling the mower? Is your drain plug tight? the right thread? (meteric vs non-metric?) if the casting is cracked, you are done. The other items are probably correctable.
Posted on Sep 07, 2009
Testimonial: "Thank you, I will look at a manual and check out your suggested possibilities."
Number 1 cylinder wear 2.5 chrysler?
you mean compression is low, right using tools?
and with added oil and not what is it. ?
doing the compression test.
oil last , and pressure rise is rings, else its valves.
low compression can not be fixed by wishes.
if the rings leak drive it
if the valves leak , it will get worse fast. fix it.
the tests are simple want to try? or just what?
Jul 26, 2014 | 1991 Jeep Wrangler
Missfire after filling oil
if you poured the oil in to fast oil might have passed threw the pcv system and flooded out a cylinder with oil or its a engine with the spark plugs in the center of the valve cover and the seals in the center leak oil and when the oil was added it drained oil into the spark plug wells and shorted out the spark plug
Sep 02, 2012 | Ford Cars & Trucks
On a poulan chainsaw, when filling with oil it runs out of the saw as fast as you are pouring it in. It seems to be coming from behind the bar and chain.
Many machines have the oil tank breather at this point is sounds like it is leaking due to it either being damaged or missing.
Apr 04, 2012 | Garden
Hi , I have a Mazda 121 model 1994. today I saw that oil leaking from my gear box so fast , how can I add oil to my gear box to before get it to garage? because I guess my gearbox run out of oil and I...
hi.
if it leaking that fast, it sound like you have a damaged seal.
i would not recommend adding more oil as it will probably come out even faster when you are driving.
the safest option would be to tow the car to the garage, or even better, have it trailered in.
Apr 03, 2011 | Mazda 323 Cars & Trucks
My 2000 alero had a leak but i put the stop leak stuff in it and it did alright for a lil while but now If you look under the bottom of the car you can see it pour out as fast as i out it in....Is it the...
If it's oil leaking, you may have a leaking oil cooler line, they have compressed fittings on them and tend to leak, I seen an Aurora with the same problem. V8 engine?
Mar 11, 2010 | 1999 Oldsmobile Alero
There are two medals hoses that run into the radiator of my chevy lumana one is leaking oil is it an oil line?
the steel lines that run into the radator are tranny lines. if there leaking I would have that fixed soon.
Nov 10, 2009 | 1995 Chevrolet Lumina
Why is car going through oil fast. Have had
You'll want to check your oil pressure sending unit. These can pour oil out very rapidly only while the car is running but when you stop, there is no indication of a leak. Thank you, Dana
Oct 09, 2009 | 1997 Volkswagen Cabrio
Oil leak at rear main oil seal 2002 chrysler sebring. it's leaking oil
To stop the leak it will have to be replaced and a speedy sleave will have to be insalled on the crank surface this is not a little job and should be taken to a shop to fix. The transmisson has to be unhooked and backed away to work on it. For a shop to do it it's about 6 hours work Guessing cause don't know if it's 4 or v-6. Good luuck, If the seal fails all the way it can pour oil out fast enough to damage the engine if you let it go.
Sep 30, 2009 | 2002 Chrysler Sebring
Oil pan gasket
A pan rail gasket usually will not leak that fast. If the leak is at the back of the engine, it's likely the rear main crank seal.
Sorry to ruin your day, but better that you find this out now and not after you did the pan..
May 05, 2009 | 1982 Ford F 250
Rav4 mystery oil leak 96 rav 112k miles, timing belt went while I was going fast, it quit and a bunch of coolant came pouring out. Within a week after this was fixed, it was completely out of oil. I...
time for a new car.  You single handedly ruined this motor.  Don't waste anymore money on this car,  buy another car and do the prescribed maintenance as required. Think of this as an expensive lesson.
Mar 15, 2009 | 2006 Toyota RAV4
Toro Lawn Mower With Toro Power Tools Logo
286 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
