Question about Smith Garden
Help! Question about Smith Deck & Fence Sprayer
  • 3 more comments
  • twenty6weeks Sep 07, 2009
    I have purchased the Smith Deck & Fence Sprayer. The insert says not to thin the water seal product, but Home Depot told me to be sure to thin it. Which shall I do?
    did you get the question?
    Shall I thin the water seal product in my Smith Deck Sprayer? Home Depot said to thin it, but the product insert says not to.
    do I thin the water seal? Home Depot said to thin it but the product insert says not to.
  • 4,281 Answers
Please explain your problem in brief.
Thanks.
Posted on Sep 07, 2009
  • 430 Answers
Sir, please provide me the Question.
  • Nandini Dhar
    Nandini Dhar Sep 07, 2009
    Sir, are you on warrenty. If yes, thin it. If any problem occurs, catch the manufacturers. If not on warrenty, reply me.
Has mold on it in places. What to use to wash off?
since you posted it wrong section auto mechanics and techs can pretty much answer all questions thrown at us so you can use a watered down bleach solution ---power washer with a mold solution or water hose with a deck--mold solution which you can buy at most hardware / home improvement stores
May 27, 2016 | Cars & Trucks
Tip
Deck and Fence refinishing
Is your wood deck weatherd and grey and you'd like to restore it with minimum effort and expense. Of course you can go to your local home improvement center and spend $$ for cleaning solutions which require a lot of elbow grease to use properly or you can follow this simple, yet very effective procedure.
  • Purchase a few gallons of regular fousehold bleach
  • Useing a soft bristle push broom brush bleach over deck surface. Almost immediately you'll see the weathering disappear.
  • When done hose off surface with garden hose and allow wood to dry completely.
  • Apply your new deck stain and behold a deck that looks almost new.
NOTE: You can use a deck sprayer in place of the broom...just be sure to wear old clothing as the bleach will ruin the clothing.
on Jan 24, 2010 | Sport & Outdoor - Others
Year of manufacture of this gun?
Need make and model as well and the serial number
Google
smith and wesson model 41 serial numbers
and you will end up here
  • S&W Model 41 serial number search - Smith & Wesson Forum smith-wessonforum.com > ... > Smith & Wesson Semi-Auto
    • 35 POSTS
    • FIRST POST: 2012-01-05
    2016-01-18 · Hi everyone....I am looking at a S&W Model 41 22 lr. I`m interested in finding out what year it was made in. The serial number is UAV1XXX. is there a ...
  • Model 41 .22 LR Need Help to Determine Year of Manufacture www.smithandwessonforums.com/forum/s-w-semi-auto-pistols-forum/...
    • 9 POSTS
    • FIRST POST: 2011-08-14
    2013-09-30 · model 41 serial numbers, s&w model 41 serial number dates, s&w model 41 serial numbers, smith & wesson model 41 serial numbers, smith and wesson model 41 ...
  • http://www.bing.com/search?q=smith+and+wesson+model+41+serial+numbers&qs=n&form=QBRE&pq=smith+and+wesson+model+41+serial+numbers&sc=1-40&sp=-1&sk=&cvid=2E13F1737AF242EB90CE478CC92D51DD
    May 23, 2016 | Sport & Outdoor - Others
    When I tighten the fence the far end "kicks" to the right from perpendicular ... andy suggestions?
    This is not an uncommon problem.
    Personally, I measure the desired width of cut from the edge of the blade to the fence, then back from the fence to one of the slots in the table deck. I then use that measurement at both ends of the fence.
    That way the fence is exactly square to the table. Takes a couple of seconds to set up but it is very accurate.
    Here's a link to a forum discussing the problem.
    http://www.ncwoodworker.net/forums/showthread.php?t=50795
    Hope it helps.
    Cheers
    Feb 10, 2016 | Rockwell 34-348 Table Saw 10"
    Is there someplace to buy a whole rubber washer repair/rebuild kit for a Roundup 4gal BP sprayer? It's square and was built in 2005 unlike the rounded newer ones. thx joe
    I've found buying one thats too big and cutting it to size and shape works best on my sprayer. You could go for a sheet of rubber and cut it all out with an exacto knife too.
    May 13, 2014 | Roundup Garden
    Truing the fence on a Powermatic 66 table saw
    There should be some screws on the bottom side of the fence that allow you to make adjustments. Loosen then slightly then set the fence to 90 degrees & then tighten them.
    Dec 27, 2017 | Powermatic 1791227K Model 64 10" Artisan...
    Manual Required for a Dulux Fence Sprayer
    search on eBay, there are tens of thousands of manuals for everything there.
    google search for "DULUX fence sprayer manual"
    Mar 07, 2011 | Garden
    Moultrie 25 gal spot sprayer for water sealer treatment
    Yes, I've used pumpup hand sprayers to apply sealers. Is the sealer water-based? If not, cleaning up the sprayer afterwards could be a chore!
    Mar 01, 2010 | Moultrie 25 Gal. Spot Sprayer
    Broken Lower Sprayer
    unlikely that epoxy will provide a permanent repair. replace with new parts - should not be overly expensive
    May 06, 2007 | Jenn-Air 24 in. DW711 Built-in Dishwasher
    Garden Logo
    44 people viewed this question
    Top Smith Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
    Are you a Smith Garden Expert? Answer questions, earn points and help others
