Question about Frigidaire FDE336RE Dryer
My frigidaire heavy duty dryer model number FDE336RES2, starts to squeak once it turns on. It will continue to do this until it warms up then it stops. How do I fix this?
  • Frigidaire Master
  • 8,220 Answers
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does? SOME PICTURES
Posted on Sep 07, 2009
My frigidaire front dryer heavy duty light stay on all the time
I appreciate your inquiry, Jnavarro073!
From the information you have provided the heavy duty light stays on all the time on your Frigidaire dryer. Could you provide me with the model number, please? With that information I will able to provide you better troubleshooting. You should be able to locate the serial tag (which lists your model number) on the door frame of your dryer. I look forward to assisting you. -Matt
Mar 08, 2015 | Frigidaire Dryers
Frigidaire model FDE336RES2 makes a squealing noise and won't turn with a full load in dryer.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 03, 2011 | Frigidaire Dryers
Frigidaire heavy duty electric dryer started with sqeaking noises now is knocking belt appears in place drum turns mannually feel somthing loose between drum and rear cover
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 14, 2011 | Frigidaire GLGR642A Gas Dryer
Dryer squeaking really loudly when drum turns. Heats though! Model FDE336RES2
its the plastic piece the drum roller rides in behind the drum in the center of the rear wall it wears down the plastic to the metal and starts screeching the drum either pops up and out of it or theres 3 philip head screws in the rear of the drum
Nov 06, 2010 | Frigidaire FDE336RE Dryer
My dryer squeels a high pitch sound until it heats up. it does ok till it starts cooling down then it squeels again. Is it the drum bearings and how hard are they to replace? It is a frigidaire Gallery...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 19, 2010 | Frigidaire Dryers
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Clothes dryer squeaks when running
Fixing Frigidaire model # FER641FSO, not stacking, but had similar problem. turnsout one of the coils came off. might try that...
Mar 01, 2009 | Frigidaire GLER331A Electric Dryer
Squealing dryer
The dryer drum support on the rear of the drum is worn and must be replaced.
It is a ball and cup design. It is worn out.
Feb 21, 2009 | Frigidaire GLER341A Electric Dryer
DRYER SQUEAKS REALLY BAD UNTIL WARMED UP
I took apart the dryer, cleaned and greased the bearing that had no grease left at all(therefore I assumed no easy movement) and it worked.
Dec 26, 2008 | Frigidaire FER231A Electric Dryer
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Dec 20, 2008 | Frigidaire GLER642A Electric Dryer
Dryers Logo
997 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
