Question about Garden
I have a johndeere lx188 rider with fd501v water cooled engine.itsmokes under aload ichanged both headgaskets ichanged fuelpump ichecked reed valves ireplaced all pushrodstwo were bent whats left ken
  • 472 Answers
Were was the push rods bent at wich end was bent
Posted on Oct 15, 2009
Fd501v kaw cranks has spark but sprays gas out the carb neck while cranking
Sounds like a damaged or badly carb'd valve or a sticking valve maybe, check are your valves opening and closing properly. thewad001
Mar 31, 2017 | Small Engine Carb Repair Tool: Mini-bike...
Have white smoke and loss of power when warm and under pressure, not on tickover
Classic case of a failed headgasket iam afraid ,no build up pressure in the cooling system but thats because its drawing in the water but the metal compression ring is acting like a valve or its leaking into the inlet side of the manifold where the water passes to heat the fuel ,either way its a head off job to make sure you do a good job
Nov 04, 2014 | Cars & Trucks
Why does my montero cooing system makes gurgling noise
In many cases of gurgling cooling system, you have a possible head gasket problem starting and the combustion from the engine is pressurizing the cooling system. Check your cooling system thoroughly for evidence of a possible blown head gasket.
Are you loosing cooling system water?
Is your radiator overflow tank being pressurized excessively by the engine. Headgasket problems can sometimes put some much pressure in that overflow tank that it begins to bulge outward.
Check the oil and look for any white/greyish milk shake consistency fluid on the oil fill cap or on the radiator cap. Keep a close eye on your oil and water levels if your gurgling sound continues. This is not normal and again, usually is a sign that there is a possible leak between the headgasket and a water jacket on the head.
Did you overheat the vehicle anytime soon? This will many times breech a head gasket between water jackets and begin spraying water in small amounts right into the engine cylinders, while it pressurizes the cooling system and makes gurgling noises.
Aug 13, 2014 | 2002 Mitsubishi Montero Sport
My engine over heated from lack of coolant, now all my cool ant is leaking out fast
check for a bad head gasket, radiator, hoses etc. or a bad soft plug. if water in oil headgasket is bad!!
Apr 02, 2014 | 2006 Chevrolet Trailblazer Ext
I HAVE A JOHN DEERE LX188 MOWER. 17 HP. GOVENOR NEEDS ADJUSTING.
Your engine per John Deere is a Kawasaki FH500V
Here is the service manual (3.58 Mb pdf file) This should get you going again.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqwm227_hwen2002_0000000-01.pdf
Jan 23, 2010 | Garden
Johndeer 335d has presure in cooling system air
most likely has blown head gasket allowing compression from engine to enter water system
Jul 07, 2009 | John Deere Garden
Drops compressiom from 120-60 psi after 3 new pressure switches
When the pressure switch fails the comperssor will overpressure to the point of safety release at about 150 - 160 psi. It sounds as if your compressor is not producing enough pressure to cycle off at 120 and just keeps running. This happens when air is leaking from fittings or worn cylinder / reed valves. Don't worry, with some simple tests we will find the actual problem. I am assuming that your compressor is oilfree type. If there are leaks the compressor may not reach set pressure. I use soapy water on all connections and on the head/headvalve (remove plastic covers to get to all parts that may leak) while compressor is running. Make repairs as necessary. If still low pressure, while compressor is running and has reached max obtainable pressure (in your case 60 lbs), carefully place finger over intake port hole (remove filter). If the compressor is pumping normally but leaking there will be ample suction at intake and cause the compressor to speed-up when intake is obstructed with finger. If you feel plenty of suction and no visible (soapy water) leaks, then the problem is probably the cylinder /ring is not correctly seating /scratched and air is leaking past cylinder. Make sure that the cylinder /piston ring is properly aligned and that the lip on the vinyl ring is up toward the head. On oilfree compressors you can examine the cylinder by pushing the piston all the way up, then look for scratches neer top of cylinder. If scratched, pressure is leaking past cylinder, install cylinder kit. If you do not feel suction but rather air blowing out of the intake, (do this test when tank has reached 60 psi) then the problem is the headvalve plate/reed valves are leaking. The reeds must seal perfectly on their seats and not be bent or have obstruction. Replace as necessary. If reeds or headgasket is leaking the discharge air will be very hot. Only one other thing to check and that is the intank check valve. Easy to check. Run compressor till you have about 50+ lbs in the tank then unplug compressor. Carefully loosen the inlet hose at checkvalve and listen for air leaking out of tank. (check valve is the brass valve at tank) If leaking replace checkvalve. Use caution when removing head to try and save the gaskets. If you have oil type pump, and no air leaks (soapy water test) suspect reed valves/valve plate. Good luck on your repair and email if you have other question.
May 06, 2009 | Campbell Hausfeld 28 - Gallon Air...
91 toyota 4x4 22re overheats on highway, but not at idle.
original issue sounded like thermostat but now that you have lost power i would have to say thermostat, blown head gasket, and warped head
to check thermostat find and remove place in pot of boiling water the see if it opens, then to ice water to check if closes.
the only way i know to check headgasket and head is to check oil and water. oil will have water in it, and water iw have oil in it
May 04, 2009 | 1994 Toyota Pickup
Garden Logo
290 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
