Question about Home
Tripps breaker at the start of the heat cycle
    President:
  • 1,564 Answers
Look closely inside the control/heater box, is a PC board (printed circuit) board. Look for signs of "frost" corrosion around the bottom of the board. if you see this the board must be replaced.
Posted on Sep 07, 2009
Unit quit in the middle of a cycle and won't power up, totally dead. Is there a suspect noise filter or fuse I should begin looking for?
Make sure your circuit breaker in the main breaker box has not tripped, or "poped". It will be one a little out of place and a bit loose if it has tripped. Turn it off and back on to reset. If it tripps immediately, you have a short somewhere, possibly in the dishwasher, so you will need an electrician and or Appliance tec. to find and fix.
Apr 10, 2015 | Samsung DMT400RHS Builtin Dishwasher
Aircon tripps circuit breaker
Usually a short in the system or its drawing to much power for the breaker to handle. most common cause is a bad capacitor, Locked up compressor or compressor has gone to ground.
Aug 30, 2014 | Dometic Rooftop RV Air Conditioner
Frigidaire Dehumidifier Tripps the Circuit Breaker after few min. running...
Sounds like your outlet is rated at 15 amps (is wired to a 15 amp circuit breaker) which is too small to run a humidifier. Most humidifiers pull 20 amps. You can check this by looking at the back panel, it will tell you how many amps it pulls or possibly how many watts.If it lists only the wattage divide the voltage by the wattage, it will give you the amps. If you have an outlet which is rated for 20 amp (usually in the kitchen or laundry room) and plug in there. If it runs you will know your problem. If this is the case be glad that the circuit breaker is working, my neighbors house caught on fire from a defective outlet that a humidifier was plugged into.Good luck, sl
Aug 15, 2012 | Refrigerators
Our rv dometic rm 0730 refrigerator tripps the breaker everytime we plug it in, and it has been plugged into three different outlet.
Obviously a short in wiring or heating element that needs to be checked by someone knowledgeable in that area. If for no other reason, safety !
Oct 27, 2011 | Dometic Rooftop RV Air Conditioner
Wondering if I mounted the flame cutoff sensor in the correct way. Does it mount onto the side of the burner unit? The dryer is now working but seems to be running hot.
The cutoff switch don't control the heat. Just tripps if the dryer overheats. The heat is judged by this cycling thermostatlthemobilian_2742.jpg
Mostly these don't over heat. The probo gonna be up in here:
Clean that blower housing out and party on!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 04, 2011 | Whirlpool LER4634J Electric Dryer
THE INSTA HEATER KEEPS TRIPPING THE BREAKER?
Is this a new install or is this something that has just come up? If it is a new install, the amperage on the breaker is too low. You will have to call an electrician to come in and check to see if the romex wire is large enough to handle a higher amp breaker. If not, it could be that the breaker has become weak and tripps prematurely. If it's not the breaker its self then the heating element is bad on the unit.
Mar 03, 2009 | Emerson Insinkerator 2.5 Gallon Water...
My oven tripps the circuit breaker when turned on
When the inside of the ovens gets hot like that what happens is that the hating leements expands with the heat and when the do the short out on the side of the oven. I just noticed the date but this is still the problem.
Nov 25, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
AC breaker trips after 10 minutes
Whats the amp breaker? Is this for the inside unit or the outside condenser? If the inside and gas heat you have a bad fan motor, If its an electric furnace , the same, but if its the outside unit, the fan could be going bad, locking up and the compressor still runs and pulls high ampsand tripps breaker or the compressor is just pulling too many amps due to plugged coils with dirt , grass or weeds blocking airflow.(koolbreezes74401@yahoo.com)
Jun 08, 2008 | Goodman CLQ36AR49 Air Conditioner
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
