Question about Vacuums
Rollers will not turn
Bag is clean and inserted correctly. power is on and exhaust is blowing out top. rollers will not turn. all belts are in place and not broken
    President:
  • 1,564 Answers
Check the reset button on the brushmotor.
Posted on Sep 07, 2009
HOW TO CHANGE A BELT
Hi there...You will need a Phillips screwdriver to get the bottom cover off.Remove the screws and then remove the bottom cover.Clean out any excess dirt in the general area of the roller bar and motor assembly area.Place one end of the belt over the steel shaft of the motor and then roll the other end of the belt on to the end of the roller bar.placing the belt on the top of the roller bar and roll the bar slowly and feed the belt onto the roller bar until it is completely in place.Replace the bottom cover and put all the screw back in.
Plug your vacuum in and turn it on with the roller bar off the floor, in other words let it run for 10 seconds until you put it on the carpet allowing the belt to position itself properly on the roller bar.
Jul 03, 2012 | Kenmore 31913 Progressive Direct Drive...
Beater bar not turning
The number one cause of the "beater bar" (or brush roller) not rotating is a broken belt.
The number two cause of brushes not rotating is that something is jammed & wound around the roller, preventing it from rotating.
For the belt: If you remove the screws holding the bottom plate, you should see one (or maybe two) short, wide rubber belt(s) that goes around the roller.
If this is broken, it's easy to replace. They do break because of age and wear. One of the leading causes of breakage is when the roller gets something - a curtain cord, for example - wrapped around it. If you don't immediately shut off the vacuum & remove the cord, the belt will continue to try to turn the roller (which can't turn), and this generates a lot of heat in just a few seconds.
You can find belts at places like Sears, Home Depot, or your local vacuum shop.
For just the roller: Turn the vacuum over on its side and inspect the roller. Will it turn? Can you see something wound around it that's jamming it? While you here, take a minute and clean the roller... including using scissors or a knife to snip & remove wound hairs & threads. A clean and healthy roller will help to keep your belt happy!
Mar 03, 2011 | Cirrus CR99 Bagged Upright Vacuum
How to install broken belt
Why would you want to put in a broken belt?
Turn the machine upside down. There are two clamps that hold the sole plate on, un click then. This will reveal the 'belt alley' where the belt runs from the motor to the roller. Lift the roller out of the slots. Take this time to clean all the hair and threads off the roller.
Put the new belt over the wooden pulley on the roller and put it almost back in. Put the other end of the belt over the motor shaft. Stretch the belt by returning the roller to its slot. Put the sole plate back on - snap the clips - Presto.
Simple
Thanks for your question today.
Feb 03, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
I have the ultimate G The belt is on, new bag, vacuum runs but no roller rotation and minimal if any suction????
On the right side of your vacuum head, there is a green belt indicator light. If when the unit is powered on and this light is not lighting up, you have a broken belt, or you didnt properly latch the belt in place.
a) Broken belt- you can use the belt from your shampoo'er if you have one, otherwise your nearest Kirby distributor has them for a couple bucks
b) As for the suction, the Kirby has 2 motors. 1 motor is for the cleaning of the floor, the other motor (where you see the vent on the left side) is for keeping the unit cool to expand the life, which btw average life of a kirby is 20yrs and they all come with a lifetime refurbishing plan. If your not getting any suction check the boot of the bag where it hooks onto the unit for any clogging
Jan 15, 2011 | Kirby Ultimate G Bagged Upright Vacuum
After shampooing carpet vaccumed worked just fine, tried to turn on next day and no power will not turn on.
Make sure the bag assembly is fully attached and snapped in place. Wet the rubber gasket on top of the motor exhaust if necessary. If the bag (or head) are not correctly installed, a safety switch prevents operation.
Dec 31, 2010 | Kirby Ultimate G Bagged Upright Vacuum
How to replace belt for hoover elite vacuum
http://www.hoovervacuumbelts.net/
How to replace
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear. Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from
cleaner body.
4. Remove agitator and broken agitator belt. (If belt is not broken but is stretched or cut, proceed with steps 7-10 and pull belt off motor pulley. Then continue with step 5.)
5. Slip agitator through new belt (with lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into
opening in cleaner body. Reposition agitator making sure to
align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
May 29, 2010 | Hoover Elite U5061-900 Bagged Upright...
I have a dirt devil featherlite plus and all of the sudden it started pushing hard and smells hot. I cleaned the roller, changed the bag, checked the belt. The belt is a little wore, but not bad.
If it is pushing hard then you still have a belt problem. It may not be broken but the belt is stretched out too long and will not turn the roller brush fast enough to make it push easy.
Nov 27, 2009 | Dirt Devil M085500 Featherlite Plus Bagged...
We have power but the front brush does not turn?
Your belt is probably broken, stretched or worn. You can get a replacement belt here:
Bissell Healthy Home Replacement Belt
Nov 25, 2009 | Bissell 5770 Healthy Home Bagless Upright...
Roller brush will not move when vaccum is turned on
maybe the belt is broken. clean the unit and replace the belt.
May 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Replacing a belt on a Sebo Automatic X1 vacuum cleaner
The roller brush has stopped turning, I think it could be the belt, how do I seperate the top from the bottom?
I will await your reply.
Thankyou Val
May 18, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
