Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
It doesn't steam anymore
When I push on the handle it doesn't steam. It only steams a little bit.
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
aq
Posted on Sep 25, 2010
Low power from steam mop
Try to be a little more vague! Model? Age of steamer? Rate of use?...Try a couple of drops of vinegar in with the water you use to fill your steam mop. The heating element that heats the water is probably oxidized, especially if you use tap water to fill it. You should only use distilled water in these mops. Some lower end steam mops have a handle that compresses, as you push the mop forward, which essentially makes the mop steam more, the more you "pump" the handle. Hope this helps!
Jan 29, 2015 | Vacuums
Shark s3601a no steam
Don't you have to push down on the handle while mopping the floor to get the steam to release. I know the one I have has a handle that slides down the shaft in forward mopping motion which releases the steam.
Oct 15, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Just purchased crofton sm 102 steam mop. instructions say will steam when light turns green. ok, it steams for about 10 seconds and thats it!!!!!! tried several times with same results
I had the same problem. Seems the little gizmo in the base that pushes up the water release valve is set a bit too low. With the water tank removed, you'll see a plastic circle with a plastic "x" in the middle. A tiny drop of glue on the "x" to raise the level a bit did the trick for me.
Apr 11, 2011 | Vacuums
My shark steam mop will heat up but not steam when i push the handle down. I have put CLR in it and let it sit over night. it still is not steaming up but it heats up. Tina
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Jul 05, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Sharksteamer not steaming anymore
Change the type of water you are using...try bottled water...
heatman101
Feb 27, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Heats up, shows steam but does not produce push of steam when handle is pumped?
heatman101
hh
Feb 20, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
When i push the handle there is no steam to clean the floor
heatman101
z
Jan 24, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
How does it work?What do you push to release the steam?
Push and pull the handle like your mopping...
heatman101
Nov 08, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
When I push the button to release steam on the handle it feels soft and no steam is released. It has been going out for a while now.
I didn't fix the problem but I did take the handle apart. There is a little metal piston that is pushed down by the button on the outside of the handle. It was very sticky and stuck in the off mode. I freed it when I took it apart but obviously it just stuck again. I am going to take the handle apart and see if a little WD40 will make it easier to push. Either that or glue it in the "on" position. I really love this appliance and if I can't fix it, I'll probably just buy something similar.
Jun 29, 2009 | Steam Fast SF-275 Steam Max Canister...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
105 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
