Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Water leaking by discharge tube
I have a in sink erator garbage disposal, model 444-3, and water is leaking by discharge tube. Is that a repairable problem. Is their a schmatic of the disosal available on the web.
    President:
  • 1,723 Answers
All you need to do is tighten the two screws on the discharge pipe (right on the side of disposal.) There is a gasket that needs tightening under the pipe fitting.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 07, 2009
Badger .5 1/2 in sink erator garbsge disposal leaks from bottom
Replace disposal, motor and electrical connections are getting wet
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 03, 2014 | Garbage Disposals
Voltage
Motor will run with 80% rated voltage that shows on nameplate.
Typical household water heater nameplate will show on side of disposal
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#voltage
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment and describe voltage that shows on side of device.
May 06, 2013 | In-Sink-Erator InSinkErator Evolution...
In Sink Erator leaks half way down
1) Copy following link for troubleshoot and replacement tips.
2) Insinkerator usually has 5 year warranty.
If unit is leaking, then replace with new disposal.
Waste King disposals have longer warranty, but local hardware sells Insinkerator/Badger for less.
Jan 18, 2013 | Electrical Supplies
Leak from area where cord comes out of the in sink erator
Not good seal could be bad are you sure it is not leaking from the top and running down the side.Fill sink all the way then pull plug get a flashlight and examine well.
Apr 17, 2011 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
The in sink erator model # 5-81A is leaking from the reset (red) button underneath. Help???
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
Oct 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaking on bottom of disposal by wire connection
Here is a tip that I wrote about how and where a garbage disposal will leak andwhat can be done to fix it.
heatman101
Sep 09, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Garbage disposal is leaking
water is bot leaking at the reset button, it is let by it.The motor seal is defective allowing water to enter the housing.. Not much,if anything can be done at the consuner level except replacement of complete unit. Call insinkerator, It never hurts to try getting their help. Somtimes if the unit is not very old they WILL help.
Jul 04, 2009 | Now Evolution In-Sink-Erator ISESEPTICAST...
My gargabe disposol won't turn off.
sounds like the wall switch needs to be replaced.
Apr 05, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
How do I change the rubber baffle that prevents
You need to remove it from under the sink and insert a new. Then reinstall. Not a real hard job if you are handy.
Kurt
Mar 17, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
741 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
