Question about Westinghouse Computers & Internet
Bought a new CPU and cannot get the image repositioned properly. Needs to come up and over to the left. Model 2401NM
  • rtuch Sep 07, 2009
    seems fine now
    thaNKS
  • Westinghouse Master
  • 19,396 Answers
Go to display properties (personalize on Vista) , and try reducing screen size to fit the screen.
I quote one of the many online tutorials:
To change the display settings, follow the procedure below:
  1. Right-click on the desktop background, and select Personalize .
  2. Select Display Settings to open the Display Settings window.
  3. To change the screen area size, click the slide under Resolution . Drag the slide to the right and left to change the size and proportion of the screen area.
  4. To change the number of colors, select the desired quality from the drop-down menu under Colors . When using more colors, the pictures and images will appear more realistic; however, more display memory is used and the display refresh time is slower.
  5. If the notebook PC is connected to multiple monitors, you can either display the same information on both monitors, or different information on each monitor.
    • Highlight the image of the monitor you want to designate as the main monitor and mark the check box at the This is my main monitor option.
    • If you want different information on each monitor, highlight the image of the secondary monitor and mark the check box at the Extend the desktop onto this monitor option.
    • If the Windows desktop is placed on the secondary monitor, when the monitor is disconnected the desktop is not visible. Leave the desktop image on the built-in LCD monitor.
  6. After you have made the desired adjustments, click OK to save the settings and close the Display Properties window.
from Change Display Settings In Vista
Posted on Sep 07, 2009
I just bought a new build I finish putting everything together and I dont get an image. The mother board debug number is 00 I know everything is compatible as my friend has the same exact build. The...
Do you have the power seated properly on the motherboard and the video card?
Do you have the video card seated properly?
-Do you have the video card in the first slot? (PCIE2 / First blue slot from the CPU)
-If running SLI suggest to use only one video card for the time being.
Is the ram seated properly?
-If using all four slots for ram suggest to only use two sticks of ram on slot A1 and B1.
Is the CPU seated properly using the CPU golden triangle to the socket corner small triangle?
If you have confirmed that everything is seated properly and the computer will still not post then you may have to call the manufacturer for a replacement or RMA.
Ref: ftp://174.142.97.10/manual/990FX%20Extreme4.pdf
Dec 18, 2012 | Computers & Internet
Cpu upgrade
You can try "support.dell.com".
Jul 03, 2012 | Dell Dimension 2400 PC Desktop
After interference, the needle won't reposition left or right properly.
sounds like something got damaged or broke & the machine needs to be checked
Mar 24, 2012 | Brother CS6000i Computerized Sewing...
I am trying to reset my toner. i am getting a toner replace message after i have replaced the cartridge with a brand new one from brother.i've tried opening the cover, hitting clear and then *00 and...
You dont say what model it is but in 90% of cases with the brother printer, it is the fault of the toner cartridge. I am presuming that the toner cartridge you put in was a generic brand. On the left hand side of the toner cartridge there is a counter reset lever that needs to be in the correct position to reset the printer. You can either return the toner cartridge and request another or try to reposition the lever & gearing by taking off the left cover.
May 11, 2011 | Office Equipment & Supplies
I JUST BOUGHT ALL NEW CARTRIDGES AND THE LEFT SIDE OF THE PAGE PRINTS REAL LIGHT. THE RIGHT SIDE IS FINE. I HAVE CLEANED THE SYSTEM WITH AIR.
The developer blades in your imaging unit needs to be cleaned. You can fix it by replacing the imaging unit for $100+ or you can clean them yourself. I have a link describing how you can do this.
http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
Oct 29, 2010 | Samsung CLP 300 Laser Printer
X2 OHP mounted on ceiling fixture. Image is dark on right side
Yes it will have to come off the ceiling. It sounds like the light tunnel has collasped. This is located under the colorwheel. If you can get a new tunnel , be careful removing the colorwheel so no segments break off of it...make sure the new tunnel is pushed against the "lip" before screwing the tunnel clip back into place.
Aug 02, 2010 | InFocus X2 Projector
I want an espresso and it's not working...
Most of the time, you just have to reposition the water reservoir - simply pull it up and then put it back in its proper place. If the water tank is even a centimeter off, the suction tube doesn't properly grab it, so it can't take in water.
If you reposition the water tank, and the EM-100 is still not sucking any water out of the tank, there may be a problem with the water reservoir tank itself. Call Cuisinart - I can't remember the Canadian number off-hand (The EM-100C is a Canadian model, so I'm assuming you're in Canada) - and have them send you a new water tank.
Good luck! Let me know if you need any more help with this machine - I am a huge raving fan.
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 19, 2009 | Cuisinart EM-200 Espresso Machine
Genius Eye110
Try adjusting the focus by rotating the camera lens to the left and right. This is probably your why the picture is fuzzy or blurry. Hope this works for you. Bud
Dec 31, 2008 | Genius VideoCAM Eye Web Camera
PRINTER CUTS OFF RIGHT SIDE OF PAPER
First, on your computer desktop. left click on START. Next, left click on CONTROL PANEL, and left click on PRINTERS. Find your printer on the PRINTERS window, and RIGHT CLICK on the icon. From the drop-down menu, left click on PRINTING PREFERENCES. Use the settings to set up the printer for the paper size and orientation you want to use.Click APPLY , then OK buttons to apply any changes you make. If that does not help,check the side paper guides in the paper source you are using. If they are not against the paper on both sides, the paper will not align properly with the image. Move the guides snug but not tight against the paper. If the guides are too tight, paper may not feed. If moving the guides does not solve the problem, try loosening the guides and reposition the paper until the image is properly aligned. Then see in your owners manual if there is an adjustment called SIDE-TO-SIDE REGISTRATION, and follow the proceedure to adjust the side-to side paper alignment.
Jul 16, 2008 | Dell 3100cn Laser Printer
ACER LCD monitor no image, appears white color only
Quickly go to the Acer website and check FAQ's and while there also find out how to get an RMA to return it. My guess is you have a bad monitor. At $200 roughly for a replacement I would hustle. I am assuming you got nothing but a white screen but did get video on your TV.
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
Top Westinghouse Computers & Internet Experts
Matthew Spark
Matthew Spark
Iqbal Husain
Iqbal Husain
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
