Question about Nokia 9300i Cellular Phone
Nokia 9300 I use a Nokia 9300...I just noticed that my speaker phone is no longer activated when it is open...what can I do?
How to format of nokia 9300i
Welcome to Fixya
This process erases from your Nokia 9300 all of your user data and settings, including your phone book, calendar, email, downloads, recordings, and certain factory installed programs such as Instant Messaging and BlackBerry Connect.
REMEMBER: Create a device data backup or synchronization before formatting.
You can restore device data and settings later. See the Nokia 9300 User Guide for further instructions.
STEP 1 - Format the Nokia 9300 memory
* Remove the battery for 10 seconds
* Replace the battery
* Open the Nokia 9300 to view the inside display
* When you see the screen with "NOKIA" in blue text,
* Press and hold the following four keys until a Format Message is displayed:
CRTL + Shift + F
* Confirm the process by selecting Format
* Formatting will begin
* After formatting is complete the Nokia 9300 will reboot with some basic settings. If prompted, accept the request to reboot
* Follow the instructions on your Nokia 9300 to set the time, date and city and to enter your contact information.
STEP 2 - Download the install-cingular-default-603.SIS to a compatible PC.
STEP 3 - Prepare a Multimedia Memory Card (MMC)1
* Transfer the .sis file from your PC to your device using MMC, data cable, Bluetooth or infrared. For instructions see the Nokia 9300 User Guide.
STEP 4 - Install the file install-cingular-default-603.SIS to your Nokia 93002
Note: This step is required to install Cingular specific settings and programs to your Nokia 9300.
* Insert the Multimeda Memory Card created in Step 2 to your Nokia 9300.
* Replace the battery cover (so the Nokia 9300 can read the MMC)
* Open your device, then open the File Manager:
Press the Desk application key
Scroll to and select Office
Scroll to and open File Manager
* Using the arrow keys, scroll to Memory Card
* Highlight the file install-cingular-default-603.SIS
* Press Open to start the installation process
* Follow and accept all prompts and requests
* Reformatting is now complete
(1) You may choose to install the file above using Nokia PC Suite. Please see the Nokia 9300 User Guide for general instructions to install software using Nokia PC Suite, and follow those instructions instead of Step 4 above.
(2) CAUTION: The .sis file above is ONLY intended for use with a Nokia 9300 with the appropriate software version. DO NOT install this file to a Nokia 9300 with any other software version. DO NOT install this file to any other model device.
Have a good one!
Mar 26, 2011 | Nokia 9300 Handheld
My nokia 9300 is on offline mode, I'm pressing the switch buttom, it's showing only offline profile is active.?Kindly suggest me what to do???
try to format it via thish code
remove sim and memory
and also battery
press ctrl+shift+f+on off swith and insert battery phone ask u format
if ur fault solve dont forgate thanx
Feb 12, 2011 | Nokia 9300 Smartphone
How to format my nokia 9300i
CRTL + Shift + F
Oct 14, 2010 | Nokia 9300i Cellular Phone
My nokia is on offline mode, I'm pressing the switch buttom, it's showing only offline profile is active
my nokia 9300 is on offline mode, I'm pressing the switch buttom, it's showing only offline profile is active.?Kindly suggest me what to do???
Oct 07, 2010 | Nokia 9300 Smartphone
My mobile nokia 9300 shows only offline profile activate how i correct it
the problem was relating to your sim card or sim network ic .check it then go to the option profile and select the general to active
Sep 19, 2010 | Nokia 9300 Handheld
Nokia 9300 me cannot make and sms of internet.
In order to solve the internet problem in phone kindly check: *whether your gprs connection is active. *configuration settings are properly filled. *home page is properly set. *verify whether your staying, where you get range. "IF YOU THINK MY SOLUTION IS HELP FULL TO YOU,THEN DON'T FORGET TO RATE ME"....THANK'S
Sep 07, 2010 | Nokia 9300 Handheld
NOKIA 9300 FORMATING CODE
this code is not working
Feb 28, 2009 | Nokia 9300 Handheld
Is there any code to format 9300 handset?
hello,
you can reset your handset by any one of the following ways:
Full Reset: (clears everything off the phone memory!! Be sure to back up your contacts!!): *#7370#, and then it asks for your security code (by default it is 12345) and then Yes.
Soft Reset: *#7780#, 12345 and then Yes. (Also works on Nokia S40 phones as a full reset)
Good Luck!!!
Jan 16, 2009 | Nokia 9300 Handheld
Mmc card on my nokia 9300
make sure the phone's back panel is in place, 9300i does not detect the mmc if back panel is removed
May 29, 2008 | Nokia 9300 Handheld
Nokia 9300i Cellular Phone Logo
66 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
