Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet 9150.. should I be able to see water in the tub when it is washing? There is no visible water level. The clothes are wet but how do they get clean?
  • 15,935 Answers
Water is drawn THROUGH the clothes. There is a BIT of water in the drum - however the water sprays on the clothes during the wash cycle and draws the dirt/water/detergent THROUGH the clothes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
My 9150 doesn't spin well and my clothes are very wet, when they come out. Then when I try to spin & drain only, it wants to run for 4 hours. Looking at the problems how good of a product did I buy.
from the description you are giving, i would guess that: 1. the "coin-catcher" ahead of the pump is plugged. 2. the tub is overloaded. 3. the loads are heavy, bulky [ blankets, jeans, towels]. when a load is too big or it is all very absorbent materials, the machine tries to balance the load before it goes into a final spin, it will not spin on high if it cannot balance - remember, ten towels or pairs of jeans soaked with water is darned heavy - mix the loads i'm familiar with this machine because i have one, i repair washers and dryers as part of my job, in my opinion, the duet is the best and most reliable washer available
Aug 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Is there a way to increase the water level on a whirlpool front load Duet washer model GHW-9150
If the machine is underfilling, check the water level switch. This diaphragm like device has a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the tube and when it reaches a certain level, it activates the switch to shut off the water and signals the timer to advance to the appropriate cycle. Make sure the plastic tube has no damage or obstruction. An obstruction can cause the switch to be activated too early.The switch can be tested for continuity using a multimeter or ohmmeter. A lack of continuity would indicate a faulty switch. Hope this helped and best wishes.
Aug 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Not enough water per load the cloths get wet but there is no water floating in the drum should there be water visible on the door?
not really...that's the point of these washers..low water usage. the clothes fall into a small puddle in the bottom over and over and rinse often.
Jun 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Ultimate Care II does not completely drain.
Mine will do this if clothes are left in it for a long period of time. The pump will not drain all water out because the will dry out the seals if they do. Your wet clothes dripped in the tub raising the water level to the bottom of the drum and that is why you have wet clothes. Remove clothes as soon as they are done, use cycle signal to avoid this.
Apr 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water level problem with duet GHW9300WHP
The best way to check this problem is to run with no clothes in it the water fill and stop three time after the third time the water level should be high in the back tapering off to not much in the front this unit wash as a chemical wash not with a lot of water
Mar 28, 2009 | Whirlpool GHW9300 Duet Washer
No visable water
you are not going to see water in the washer, it only lets in enough to wash the clothes
Mar 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Can i adjust the water level on my Duet?
Sorry there is no way to adjust the water level. the washer decides how much water by how much clothes are in the washer .
Jan 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite calipso was motion
calyso is a low water use machine similar to front loads only enough water enters machine to get clothes soaking wet water is recirculated through tube on back right corner of tub to insure clothes are soaked if pressure switch determines minum water level not reached it will add more
Apr 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Low water level
It depends on how old the machine is, the newer machines by law,take in way less water but still wash ok. TIP.try it with out load and check water level Ire bye
Nov 04, 2007 | Whirlpool GHW9200L Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
163 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
