Home | Weber | Genesis Silver B Grill | The regulator and hos...
Weber Genesis Silver B Grill
Problem for Weber Genesis Silver B Grill
The regulator and hose from tank to grill have
By sepeterson11 on Sep 07, 2009
The regulator and hose from tank to grill have frost/ice buildup - is this a sign of a leak ?
Best Solution
posted on Sep 07, 2009
Very Helpful)
bulldogchief
Rank: Guru
Rating: 93%, 135 votes
No, if it were leaking you would smell the strong odor of the gas. The gas is pressurized in the tank, when you open the regulator and light the grill, it is normal for the regulator to become very cold and therefore frost buildup. Cheers!
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Weber Genesis Silver B Grill
Questions and Unsolved Problems for Weber Genesis Silver B Grill
Do you recommend Weber Genesis Silver B Grill?
Answer
Answer
I turn on gas the grill ignites and after 5 seconds it shuts off and won't ignite again until I wait... (More)
Answer
The front burner dial is stuck - can it be replaced? If so how and what parts/tools are needed?
Answer
My grill is not lighting as hot as it use to. I don't know if that is what is causing the problem by... (More)
Answer
I inadvertently put the washers on my grill wheel assembly incorrectly. How can I get them off?
Answer
The fire box (the lower main box which houses the burners and grate and to which the cover attaches)... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Weber Genesis Silver B Grill:
Top Grill and Smoker Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Grill and Smoker Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
