Question about Singer 8280 Mechanical Sewing Machine
My 8280 modle singer: I sewed a zipper for a shirt, but the needle hit the hard part of the zipper, so the needle broken, when I replaced a new needle, but found that that machine stuck, even I push the foot paddle hard or use my hand to move , the machine stopped moving. What should I do now? Thank you for the help.
  • Singer Master
  • 1,388 Answers
If you are not able to free this easily, you really should consider taking it to a service technician to look at it in case you do more damage to the needle bar and elsewhere trying to fix it yourself.
Posted on Sep 08, 2009
Why is needle hitting zipper foot on left side only?
When the needle is set on the center position, is it centered or is it slightly off center? If so, then the mechanism needs to be adjusted so that the needle is perfectly centered. When it is off-center, you will get the problem you are experiencing with hitting one side of the zipper foot. May want to take it in for service.
Mar 13, 2016 | Singer 4411 - Heavy Duty Model Sewing...
What size needle for Merritt singer 3014
I could not find a Singer Merritt 3014 nor a Singer 8280. Do you have the serial number and/or model number? You can always try this site:
http://www.singerco.com/products
Jun 11, 2014 | Singer 8280 Mechanical Sewing Machine
Frequent thread breaking
Hai, Please check the thread tension and change the new thread and new needle. Otherwise put the some drops oil in the top and bobbin thread. Or go to mechanic shop.
Apr 16, 2014 | Singer 8280 Mechanical Sewing Machine
Replacing needle
the sewing machine problem was put under the machine model
number 8280, so I found a free manual for the machine & it should
tell how to replace a needle
http://www.singerco.com/uploads/download/430_8280_es.pdf
Sep 03, 2012 | Singer 8280 Mechanical Sewing Machine
Breaks needle
Yes they can indeed go out of time and breaking needles is the most likely cause. To solve timing problems you will need a sewing machine engineer though. The part which needs adjusting would be the area above the needle-the needlebar but it is a fiddly affair only to be attembed by someone who can repair sewing machines. It is also a fairly expensive repair as it is very time consuming. However-don't assume it is that. Firstly make sure the new needle is in correctly-the most common cause of problems is needles in wrong direction! If bobbin opens at front then the flat part of the needle faces the back. If bobbin area opens at side then the flat side of needle faces the body of the machine to the right. Check needleplate for damage so that new needle does not catch. File it smooth if you need to! Check you are using a good quality thread as cheap thread causes no end of problems. Guuterman is the best I found.
Feb 14, 2009 | Singer 8280 Mechanical Sewing Machine
New singer 8280 needle hits overcasting foot and breaks
so, it sews for a while?  It sounds to me like the screw that holds the needle in place is loose.  As the needle moves up and down the screw loosens until that one fateful stitch, it comes out completely.  Try to tighten with a screw driver.
the other possibility is that it breaks if you are sewing over a bulky seam, like a flat fell.  as the presser foot "toes up" to go over the lump, the needle hits and there you are.
holler if that doesn't help.
Jan 18, 2009 | Singer 8280 Mechanical Sewing Machine
Singer 8280 Mechanical Sewing Machine Logo
206 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
