Question about American Standard Town Square Two Lever Handle Widespread Lavatory Faucet
How do I take a loose handle off of an American Standard Hampton faucet?
  • 30 Answers
The following link is the installation instructions for your faucet.
http://www.americanstandard-us.com/assets/documents/amstd/install/Install_555.pdf
Basically, what you need to do is gently pry the cap (with the hot/cold indicator) off the top of the handle. This will expose a screw-head, that you tighten to fix the looseness or loosen to remove the handle. If it's the other part of the handle that's loose (the bit that sticks out sideways rather than the whole handle). I've attached a diagram of how that is attached.
http://www.americanstandard-us.com/assets/documents/amstd/parts/Parts_555.pdf
Posted on Sep 18, 2009
Sunken bathtub
Is there are question in this somewhere?
May 04, 2013 | American Standard Hampton Two-Handle...
Base of faucet leaks- cannot remove set screw at handle American Standard Elite kitchen faucet series 4453
if you are having trouble removing the set screw make sure you are using the correct size allen wrench and confirm that it is a allen screw and not a trox screw. After doing this try tighten the screw slightly before loosening it. This should break it loose.
Feb 25, 2011 | American Standard Kitchen Faucet 6310 020...
Installed bath 3 handle unit. hot handle is stiff and hard to turn, shower diverter is loose. How can I loosen the one and tighten the other? I'm sure it's probably the same adjustment
The handle adapters can be tightened by turning them clockwise and loosened by turning them counterclockwise. If the faucet manifold may need to be lined up parallel behind the wall and moved forward as well. Here is the parts breakdown for your faucet,
Sep 05, 2010 | American Standard Hampton 7225.733.002...
Cold water handle on my American Standard cold water control just spins around with out turning on the water
There is an adapter from the faucet stem to the handle. A small gray plastic faucet part that frequently causes problems for many owners. You will need to call American Standard and ask for a new handle stem connector. The faucet came with a limited lifetime warranty and the part should be free. While you are getting one, you might as well get another for the other handle. American Standard's phone number is 1-800-442-1902.
Sep 05, 2010 | American Standard Hampton Two-Handle...
T980.732 faucet handle (one only) not working
I'm leaning towards handle adapter over cartridge. It is plastic and doesn't tolerate a lot of stress. Go to the link below for parts breakdown and A/S hotline number at the bottom left of page. A/S should also be able to provide you with the correct replacement cartridge and/or part number for your roman tub faucet.
http://www.americanstandard-us.com/assets/documents/amstd/parts/Parts_542.pdf
May 31, 2010 | American Standard T980.722.234 Satin /...
American Standard single handle faucet
if it is 25 yrs old it might be to your favor to just replace the fixture.parts for something this old may be hard to find good luck.
Apr 22, 2009 | American Standard Reliant+ 4 In. Single...
Faucet sounds like a fog horn
It sounds like the faucet washer has come loose. Pull out the valve and replace the washer or just tighten the screw.
Please rate if this helps-
Mar 27, 2009 | American Standard Hampton Two-Handle...
Kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Oct 16, 2008 | Plumbing
American Standard Town Square Two Lever Handle Widespread Lavatory Faucet Logo
283 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
