Question about Philips DVDR725 DVD Player/HDD Recorder
Sungale dvd2026 when I put dvd in it wont load. Screen says wrong disc in upper right hand corner. What do I do? Dave
  • 1 more comment
  • bofubum Dec 21, 2007
    dito. Wrong Disc and not dvds will load.
  • MuskogeeGirl Jan 06, 2008
    I also have the same problem and have tried every disk and dvd that I can think of. It always says wrong disk. I have two of the same units that I got as a promotion with Direct TV and both of them do the exact same thing.
  • Anonymous Apr 20, 2008
    Same problem here. I was able to get mine to play a dvd once. I went into it's menu programming and reset it's options to defaults. But, this only worked once.
I found a "hack' to make mine work :)
1. Open the tray
2. Press "Setup": Menu Screen should appear
3. Press "8-8-8-8" ( if you changed the password, you might have to change it back to 8888 ) The region number should appear on upper right corner. No other notation. Typically just the numeral "1".
4. Use the right (->) or left (<-) arrow keys to change the region to 255 for all regions.
5. Use the up or down button to go to 3001 and 4000. I had to change 4000 to 4001 to get mine to work,
6. Press "Setup" to exit.
It was a big relief to find this hack, because I misplaced my receipt and thought I was simply out of $30.
Posted on Apr 20, 2008
My toshiba dvd/vcr combo suddenly wont read dvd disc
Maybe the lasers ok but the disc motor is not spinning the disc.
Apr 28, 2014 | Televison & Video
Where do I buy a remote for DVD2026
Original remote for Sungale dvd 2026 is hard to find. Right now I am selling one RC on Ebay. It is a second hand but in working order. I am selling RC because my dvd was damaged in a blackout
Aug 03, 2009 | Sungale DVD-2026 DVD Player
I need the codes for a sungale dvd player
manufacturer code for dvd2026 of north america
Mar 04, 2009 | Sungale DVD-2026 DVD Player
No discs will load
if the circle is always showing up on the top right corner of the screen and doesnt load any games that means that you laser pick up is already busted.bring it to the nearest sony workshop for a replacement.
Dec 16, 2008 | Sony Playstation 3 (PS3) Console
CD won't play
Your lens might be dirty.Open the cover of player and identify the lens.Its a little glass eye.Get a clean cotton cloth dipped in methylated spirits gently rub surface of lens. Give some time to dry and replace cover.You should be ok.
Jul 19, 2008 | Cyberhome CH-DVD 300 DVD Player
Wrong disc message displayed on screen for dvd-2026
I found these posts. I have only been able to get the fix to work once, though. :(
1. Open the tray
Region code hack posted by jeff777, December 15 2004:
This works.
1) With remote control, power the DVD player on.
2) With remote control, open the DVD tray.
3) With remote control, select SETUP.
4) With remote control, press the VOLUME UP button, then the VOLUME DOWN button, then the VOLUME UP button again and finally the VOLUME DOWN button again.
5) You should now see a number 2 on your screen. If you do not, this hack will not work on your system or you have done something wrong. If you do see the number 2 on the screen, proceed to 6).
6) Use the LEFT and/or RIGHT arrow to select the number 255.
7) When you see the number 255, press the SELECT button.
8) Press the SETUP button again to end procedure.
Region code hack posted by RayH, May 18 2005:
Newer Sungale 2026 players are a bit easier to set up:
1. Open the tray
3. Press "8-8-8-8" Region number should appear on upper right corner. No other notation. Typically just the numeral "1".
4. Use the right (->) or left (<-) arrow keys to change the region. "255" all region.
5. Press "Setup" to exit.
Tested Region 1, 2, 3, 4, and 5 PAL and NTSC disks. They all work just fine on an older US NTSC TV. It's a little bigger than the Cyberhome, but works much better. There is no jerking at chapters with either factory or homemade discs. Plays VCDs just fine.
Sniff around the internet. This machine is availabe as of 5-18-05 for about $29 plus shipping ($11). Arrived in two days.
Other hack posted by Hurricane, January 23 2006:
If you do the Setup>8888 thing you get a region code 1-6 & 255.
Well if you press up and down on the directional pad you also get 3001 and 4001 these can be changed to 3000 and 4000, I know that one of them is a Macrovision on/off flag but I don't know what the other is.
Region code hack posted by Streetmedik, March 25 2006:
I have the Sungale DVD2026 I have tested this with DVDs from various regions. It works.
1. Power on
2. open the tray.
3. ON THE REMOTE press the VOLUME up, down, up, down.
4. ON THE REMOTE press SETUP
5. ON THE REMOTE press the up and down arrows to go between the macrovision/region codes.
6. ON THE REMOTE press the left and right arroes to change the values.
Macrovision
3001 on
3000 off
Regions
1,2,3,4,5,6 = individual regions
255 = all regions
7. ON THE REMOTE press setup again and you are set.
You can change these values again and again If you just want to play around.
Mar 22, 2008 | Sungale DVD-2026 DVD Player
Freezing
damaged or dirty disc-clean or replace
ron
Dec 27, 2007 | NexxTech DP3222 DVD Player
Sungale dvd2026
i was just looking into updating the software on the pvr at philips.com. While reading the instructions, it mentioned that updating the software version would require me to go thru configuration again. This may include the parental code. Worth a try.
Nov 05, 2007 | Philips DVDR725 DVD Player/HDD Recorder
Discs wont play
what is the model and brand of your dvd player kindly post it on this website and please say how long the set have been refusing disc, and how old is the dvd player will be awaiting.you can contact me through fixya or my email nicodhem@yahoo.com see ya
Mar 26, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
"wrong disc" display
I have the same problem with my DP313 Norcent. I found though that it will play recorded dvds. It also will play older Dvds and some Anime ones. It will play older recorded mp3s but NOT newer ones, I'm not sure if it's because they are burned at a faster rate or what. Also it will not play any of the new dvds except as stated before some of the Anime ones. It pays to try everything out to ensure it not a mechanical problem. I found it's not with mine, but still unsure why it won't play new dvds?
Oct 10, 2006 | Norcent Technologies DP313 DVD Player
Philips DVDR725 DVD Player/HDD Recorder Logo
200 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
