Our hotpoint aqurius wont rinse properly on its last cycle it doesnt empty properly
  • 379 Answers
Most probably the pump has partially or completely siezed/failed.
Early machines had the pump in a position where condensation dripped on to the motor and over time caused the motor to seize.
Never worked on a modern Hotpoint but I suspect even if not due to the same cause, pump not running is your best bet.
Posted on Sep 07, 2009
Wash cycle selector knob just keeps going around
sounds like a mechanical defect. Anyway, I think you need to invite a technician.
Jul 16, 2014 | Hotpoint Washing Machines
My aqurius WMF760 Hotpoint doesnt fill with water, we had this once before so i unpluged it from the mains waited 5 min then plugged it back in, this worked, same thing has happened again but trying the...
Congratulations on owning one great dishwasher.
There are only a few things that can and do go wrong or wear down.
Please click HERE to see exact instructions set up just for this situation.
If this get's you going please rate my high and pass along a good comment.
Thank you for letting the FIxYa Team help.
Gary.
Apr 27, 2010 | Hotpoint  Standard Range Hood
Hotpoint bwm129 wont finish a cycle. super wash and rinse hold lights are flashing.have checked pump for obstructions and waste pipe. any suggestions?
Have you checked the filter? even if the pump is o/k, if the filter is blocked, it will not empty..
If filter clear, then you have a more serious problem.
Hope this helps.
Dec 02, 2009 | Hotpoint BWM12 Front Load Washer
Aqurius fdw 60
Ensure that your filters are not blocked - these are inside the unit. remove the grey plastic filter and see if there any food or other items jammed in it.
Make sure there is nothing underneath the filter - if there is items of food (e.g seeds) may already be restricting the exit pump path.
Jun 17, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Fills washes rinses but wont spin properly or empty out washer, ends cycle half done, wont pump water out or spin out. i can hear the machine hum while trying to do so. Please any ideas. THanks
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Oct 19, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Washer Won't Rinse (Hotpoint)
Suggestion: Try cleaning your outlet filter. This needs periodic cleaning, according to your usage. Refer to user's manual re. the cleaning. When it is the rinse problem it usually is the filter block.
Oct 05, 2007 | Washing Machines
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
